Help big brakes and spare tire - Team Camaro Tech
post #1 of 10 (permalink) Old May 2nd, 17, 06:39 AM Thread Starter
Paul
Put willwood 12.19 big brake kit on my 69 with 18 in wheels , now I'm looking for a spare incase of flat without spending an arm and a leg, 15in ralley doesn't clear caliper, any suggestions?
Paul O is offline
post #2 of 10 (permalink) Old May 2nd, 17, 07:19 AM
Nick
I don't carry a spare since i had my trunk interior redone with carpet and panels. I have the AAA membership with 4 free tows in case i need them. I only drive my car 2 times per week also.
Nicc21 is offline
post #3 of 10 (permalink) Old May 2nd, 17, 07:20 AM Thread Starter
Paul
Will wheels off a 12 or newer Camaro fit a 69?
Paul O is offline
post #4 of 10 (permalink) Old May 2nd, 17, 07:20 AM
Patrick
Re: Help big brakes and spare tire
Be careful. When I asked the same question, everyone told me I needed to get a cellular telephone.
https://www.camaros.net/forums/17-whe...ified-car.html
An 18" donut spare tire out of a 2014 Camaro clears my Wilwood 14 inch rotor and 4 piston caliper.
Patrick
tp_smith is online now
post #5 of 10 (permalink) Old May 2nd, 17, 07:35 AM
Maybe you should just put run-flats on the car like the Vettes use.
1967 RS/SS 350 Conv - triple black, 4sp, tach & gauges
1969 VN-built RS/SS 396 Conv - Garnet Red/Black, 4-sp, tach & gauges
RSSSfanatic is offline
post #6 of 10 (permalink) Old May 2nd, 17, 08:06 AM Thread Starter
Paul
I have AAA also, don't wanna spend money on run flats lol . I have the six piston calipers, I'll give that a try thanks
Paul O is offline
post #7 of 10 (permalink) Old May 2nd, 17, 08:27 AM
Simon
BMW rims have a close bolt pattern, you need 5 x 120.7mm, BMW 5 x 120mm, older rims have a offset that might work.
Small spacesaver rims are costly cause everyone wants them for vettes as well, try finding 2004-2006 GTO spares.
When it all said and done see if you can find a single 17 or 18 inch rim and a tire, it might be cheaper in the long run.
https://www.summitracing.com/int/par...3445/overview/
slazisme is offline
post #8 of 10 (permalink) Old May 2nd, 17, 08:37 AM Thread Starter
Paul
Thanks fellas, I appreciate the help... A lot.
Paul O is offline
post #9 of 10 (permalink) Old May 2nd, 17, 09:07 AM
DjD
DjD's Avatar
All of the above, sort of... I have a space saver and plan to get a wheel spacer so it can be used front or rear but haven't gotten it yet. I carry a can of fix-o-flat, a cell phone and have 200 mile towing through AAA. Been many years and many long drives and (knock on wood) haven't needed any of the items mentioned. I keep planning on getting a plug kit and a 12v emergency compressor to replace the fix-o-flat because I really don't want to deal with the green slime.
...Dennis
DjD is offline
post #10 of 10 (permalink) Old May 2nd, 17, 01:42 PM
Brent
67Rally's Avatar
GTO spares command a premium price, you can probably find a newer Camaro spare a lot cheaper.
67Rally is offline
