Front tires rubbing, what to change, how far to go... - Team Camaro Tech
 1Likes
  • 1 Post By Old Dad's 67
post #1 of 6 (permalink) Old May 23rd, 17, 05:27 AM Thread Starter
Bucky
During this winters restoration I ran into some issues we noticed on the front tires rubbing on the fender wells. Not that I ever really noticed it but I guess it happened based on what we found.
I have 215-70-r15 on the front and 225-70-r15 on the back.
Here is what I am looking for advice on?
I was thinkinf of going with a 205-70-r15 on the front that will stop the rubbing on the newly repainted wells. Do you think it would look goofy or noticable if I keep the 225's on the back or should I move the 215's to the back? Or just run the backs with 225 and 205 on the front?
Thanks fellas
1967 RS Convert. numbers matching 327/275 with 4 speed hurst on top of a saginaw, 12 bolt 355 rear end, console w/gauges & deluxe int., ORIGINAL PLUM!
Let's Roll!!
imbucky is offline
post #2 of 6 (permalink) Old May 23rd, 17, 06:01 AM
Chad
cv2065's Avatar
Re: Front tires rubbing, what to change, how far to go...
Why not just use a small spring spacer? I used a 3/8" aluminum spacer from Global West and it worked great, although it creaked from time to time.
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #3 of 6 (permalink) Old May 23rd, 17, 06:40 AM
Jeremy
A lower profile tire would also help with the rubbing. Going from a 215/70r15 to a 215/65r15 is almost a 1" difference in height. This site lets you plug in tire sizes so you can see the size difference side by side. https://tiresize.com/calculator/
Jeremy
1967 rs, 355, pontiac 867 heads, crower rockers, Isky roller cam, FiTech Power Adder 600, Hurst Drivelines T-56 Magnum, RAM clutch, 4.10 posi, Vision 18" wheels
wireboy355 is offline
post #4 of 6 (permalink) Old May 23rd, 17, 07:08 AM
X2. What wheels size and backspacing are you running?
Your challenge is tire height with the 70 series. Most applications I have seen in 15" wheels are 60 series tires. If you really want to stick with 70 series, the 205s in front and 225s in back will look good. You can always swap the 215s to the rear if you're not happy with the look.
imbucky likes this.
Old Dad's 67 is offline
post #5 of 6 (permalink) Old May 24th, 17, 07:48 AM Thread Starter
Bucky
This ishe route Im going to try witht he 205's
Thanks, Ill let you know how it goes....
Let's Roll!!
imbucky is offline
post #6 of 6 (permalink) Old May 24th, 17, 08:50 AM
Good luck Bucky. Do you best to check for clearance before you leave the tire shop. You may be able to get them to try other sizes if the 205s don't cure your rub issues.
Mike.
