what would it take to run 15x10 on my 67 camaro? - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 4th, 17, 09:31 AM Thread Starter
Apprentice
donnie
I'm doing another street car its a 67 Camaro will have stock width rearend and I have a set of mint 15x10 centerlines with 51/2 in back space do not want to mini tub or cut fenders, will these fit ? if sold I need to use a short shackle? or airshocks to raise rear alittle? or will they ? no one will be in rear seat as it will be removed,
dads67z is offline
post #2 of 8 (permalink) Old Jun 4th, 17, 09:54 AM Thread Starter
Apprentice
donnie
Re: what would it take to run 15x10 on my 67 camaro?
tires on 15x10 centerlines are 275-60-15
dads67z is offline
post #3 of 8 (permalink) Old Jun 4th, 17, 10:09 AM
I don't think it can be done without rubbing unless you lift the rear up a couple to a few inches to clear the outer fender wells.
Here is a link that may help. https://www.camaros.net/forums/17-whe...fitment-2.html
Old Dad's 67 is offline
post #4 of 8 (permalink) Old Jun 4th, 17, 11:00 AM
No mini tubs, no fit.
If you measure from wheel mounting surface to inner wheel well....its about 6" and from wheel mounting surface to outer wheel well lip its about 5".
68 Camaro~LSx ~all motor
post #5 of 8 (permalink) Old Jun 4th, 17, 11:51 AM
kevin
this is a 68 with shackes with 15X10 centerline , I am old school !!!!!!!!!!!
flat tire is offline
post #6 of 8 (permalink) Old Jun 4th, 17, 03:22 PM
Greg
pittpens24's Avatar
I was able to get 295/50R/15's mounted on 15X10's on my car with a stock rear. I did have multi-leaf springs and did not have shackles but did have air shocks that I eventually changed out to coil over shocks in the rear. The tires did stick out a little but I never had any rubbing issues.
ID:	185177   Click image for larger version
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #7 of 8 (permalink) Old Jun 5th, 17, 05:06 AM
Bruce
I have a pair of those for sale!!! Modernize the old dog!!
The Camaro Guy is offline
post #8 of 8 (permalink) Old Jun 5th, 17, 02:20 PM
I have 15x10 centerlines on my 67. 3-1/2" back space. Lifted with air shocks, but my 28x10.5 slicks don't rub.
I don't think the 5-1/2 back space will even come close. Maybe a 4-1/2 back space with shocks relocated.
marks412 is offline
