Rally Wheels On a 69 - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 7th, 17, 07:21 PM Thread Starter
Probationer
Daryl`
I picked up a set of rally wheels 15x7(4.25 BS) and 15x8(4.50BS). can someone post up pics with this set up. Trying to decide on which size tire. Thinking about 225/60/15 and 255/60/15. Thanks
1969 Camaro Z28
SASQUATCH01 is offline
post #2 of 8 (permalink) Old Oct 8th, 17, 04:20 AM
Kevin
KevinW's Avatar
Re: Rally Wheels On a 69
Welcome Daryl! While I cannot help with the tire selection, based on the rim size, you have a FW 15x7 from a Monte Carlo and probably a 15x8 from a vette. You might have some trouble with matching the trim rings that fit those rims. The 15x7's are easy, same as a Z, but the vette trim rings that fit the 15x8 have a different profile. Maybe someone here with that combo has some advice.
Kevin
KevinW is offline
post #3 of 8 (permalink) Old Oct 8th, 17, 06:21 AM
Chris
Daryl,
Attached is a photo of that exact wheel/tire combination. I did not spring for the wider trim rings for the 8" wheels in the rear and instead used the trim rings from my original 7" rims. I think the 8" trim rings have more of a rounded shape as they transition over the edge of the rim whereas rings for my 7" wheels had a sharper transition and I did not want to mix those shapes. I've since changed wheels and tires, but the rally wheels with BFG's worked very well for many years.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #4 of 8 (permalink) Old Oct 8th, 17, 06:57 AM
Josh
Daryl I am running the same setup on my 68. Here are some pics with a 255/60/15 on the back and 225/60/15 on the front.
68 Z/28
383, M-20, 8.5 w/ 3.73's
jcihos is offline
post #5 of 8 (permalink) Old Oct 8th, 17, 08:47 AM Thread Starter
Probationer
Daryl`
Thats the exact look I want. I did pick up the 3 inch rings for the back and 2.5 for the front. Ill have to see if I like that when i get my tires and get them mounted on the car. Beautiful car BTW.
1969 Camaro Z28
post #6 of 8 (permalink) Old Oct 8th, 17, 08:50 AM Thread Starter
Probationer
Daryl`
Originally Posted by ctcz28 View Post
Daryl,
Thats the exact look Im going for. I ended up getting the 3 inch rings for the back but might change them after I see how they look. Beautiful car BTW
1969 Camaro Z28
post #7 of 8 (permalink) Old Oct 8th, 17, 10:15 AM
DjD
DjD's Avatar
When I bought my '69 ragtop it had 235/60/15's on all 4 corners with 15x7 4.25 bs (FW and YH designated) I put Vette 15x8's on the back with 255/60's and the tires rubbed the fender lip so put the 255's back on the 15x7's. My car sat lower than Chris' though. I also ran the 7" trim rings on the 8" wheels for the short time they were on the car.
...Dennis
DjD is offline
post #8 of 8 (permalink) Old Oct 11th, 17, 04:30 AM
Bruce
I have the Vette wheels on all 4 corners running 235/60 and 255/60 stock height and no rubbing issues. I really like the look of the deep 8" wheels over the 7". . . . JMO
The Camaro Guy is offline
