Help with my 67 Camaro set up - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 15th, 17, 05:05 AM Thread Starter
Apprentice
Chris
Notching off things to do with my 67 Camaro. Next on the list is rims/tires. It has the stock clearance, only thing done so far was springs to support the ZZ572.
-Thinking 18?s would be good, slightly wider in the back. Any thoughts? Anyone running 19s in back, 18s in front? Pics would be appreciated
Merrozz572 is offline
post #2 of 3 (permalink) Old Oct 15th, 17, 06:42 AM
Greg
pittpens24's Avatar
Re: Help with my 67 Camaro set up
Check out the search bar ^ - there is a ton of info for your year with stock clearances for wheels and tires as well as plenty of pics.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #3 of 3 (permalink) Old Oct 15th, 17, 08:39 AM Thread Starter
Apprentice
Chris
Thanks that helped a lot. Going to get
(Rear)
18x9 w. 5.25 back spacing
255 or 265x40x18 tire
(Front)
18x8 w 4.75 back spacing
225 or 235x40x18 tire
