Rims that fit 69 camaros help - Team Camaro Tech
 5Likes
post #1 of 22 (permalink) Old Oct 30th, 17, 11:48 PM Thread Starter
Apprentice
Kevin
Basically I got my 1969 Camaro awhile back and dude spaced the Rears out a bit with a 15" x 10'' x 3.25" back spacing rim, they hook great with the 255 - 60 x 15 rubbers on them, only thing is they rub just a little bit on the shoulder, kinda hurting the mickeys, but I dont have the cash to get all 4 new rims. found a replacement american racing replica of the center line style that might work if I cut out the outside inner fender well lip and bend it in and grind it smooth, the new rim is 15 x 10 x 4" back spacing. only .75 back space difference but do you guys think it may work? If not I was thinking of getting the 8" wide rims but not sure if it'll take off enough, the 10" wide ones just square the wheel up to it so nicely, and advice would be great guys!
Itll be a $250 guess but I think itll work. any body else been in this scenario?
stewroids is offline
post #2 of 22 (permalink) Old Oct 31st, 17, 03:29 AM
Greg
pittpens24's Avatar
Re: Rims that fit 69 camaros help
You already have the equation - you just need to do the math. If you have a 15x10 with 3.25 BS and it is rubbing, just figure out how far inboard you can go without causing an issue and add that to the BS you already have assuming you will be using the same size tire. Be sure to allow for body roll and the suspension to work.
Now that I think about is, a 255 might look better on a 9" wide wheel. I had 15 x 10's mounted up with 295's back in the day and they did not rub with multi-leafs and coilovers but I think I had a 4.5 BS
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #3 of 22 (permalink) Old Oct 31st, 17, 06:17 AM
Vega$69's Avatar
10” wheel is too wide for a 255/60R15
Ideal width is 8”
arocars and 57vette like this.
Vega$69 is offline
post #4 of 22 (permalink) Old Oct 31st, 17, 06:45 AM
Are you sure it is a 10” wheel? Did you measure it to be 10 inches? If you did that is likely a 9” wheel.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #5 of 22 (permalink) Old Oct 31st, 17, 05:34 PM Thread Starter
Apprentice
Kevin
Thanks for the input everyone! Curious why you would want to run an 8" rim instead though, the 10" squares up the tire nicely, Only reason I want to see what you all think of it is because of the current budget. Looks like I may end up running the 8" rims with 4'' back space since that all that American offers.
If I go to a 8" wide rim instead it'll squeeze in the tire a half inch or so wouldnt it?
Got lots of body damage in the rear so not too worried about folding in the inner lip on the fender haha
post #6 of 22 (permalink) Old Oct 31st, 17, 05:42 PM
Vega$69's Avatar
Tire manufactures recommend ideal rim widths to maximize the designed performance on the tire.
A wheel width the same or close to the tread width is not typically ideal. Has to do with side wall flex when cornering and other factors
Vega$69 is offline
post #7 of 22 (permalink) Old Oct 31st, 17, 06:20 PM
Chris
I ran 255-60-15 BFG's on 8" corvette ralley wheels with no rubbing.
57vette likes this.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #8 of 22 (permalink) Old Oct 31st, 17, 06:47 PM
I don’t believe you are running a 10” wheel with 3.25” backspacing. It would stick out well past the quarter panel if I did the math right. Normal backspacing for a 10” wheel on a 69 is 5.75”-5.875”....
dhutton is offline
post #9 of 22 (permalink) Old Oct 31st, 17, 06:52 PM Thread Starter
Apprentice
Kevin
Yeah bro its 10 x 15, measured it and the backspacing lots of times to make sure I did it right, sticks out a bit, that why I want to fix it
post #10 of 22 (permalink) Old Oct 31st, 17, 06:55 PM Thread Starter
Apprentice
Kevin
Right on man good to hear! Remember the backspacing at all? and was it a 69 Camaro by chance?
post #11 of 22 (permalink) Old Oct 31st, 17, 06:56 PM Thread Starter
Apprentice
Kevin
Gotcha man, Just looked up Mickeys stuff and an 8 should do the trick on size, 4" back space should help with Knocking back the rim size
post #12 of 22 (permalink) Old Oct 31st, 17, 07:22 PM
If it measures 10 then it is a 9 inch wheel....
dhutton is offline
post #13 of 22 (permalink) Old Oct 31st, 17, 07:38 PM
Chris
right on man good to hear! Remember the backspacing at all? And was it a 69 camaro by chance?
Yes, mounted on my '69, 4.5" back space. Search this site for feedback from others on what fits and what wheels they've used.
ctcz28 is offline
post #14 of 22 (permalink) Old Oct 31st, 17, 09:05 PM Thread Starter
Apprentice
Kevin
Cool man thanks for the info! Thats why im posting about it to see what'll help me out Wish I could afford a whole new set right now but I'll try these @ 4'' and get 8" rims for her
post #15 of 22 (permalink) Old Nov 1st, 17, 05:25 AM
Chris
I get the car budget issue, but I'd wait and watch for a set of used wheels with the correct back space and width to fit your wheel well before I'd cut up my rear quarters. You can always change wheels/tires, but once cut, you can't go back and you may not like the result. Look at Summit or Jegs for a pair of Wheel Vintiques ralley wheels with the width and BS you need, they are not too expensive and better than cutting up the car unnecessarily. Craigslist, racingjunk.com, swap meets.....
Then there's always air shocks.
ctcz28 is offline
