10" wheels and 275's ??? - Team Camaro Tech
 3Likes
post #1 of 23 (permalink) Old Nov 6th, 17, 02:25 PM Thread Starter
Has anyone put a 275/60/15 on a 10" wheel on a 67or68 Camaro with stock wheel wells ?
Pics ?
Roll lips ?
Backspacing ?
Thinking of some new wheels ?
68 Camaro~LSx ~all motor
post #2 of 23 (permalink) Old Nov 7th, 17, 03:18 AM
Greg
pittpens24's Avatar
Re: 10" wheels and 275's ???
I got 275's up front - nothing stock, but running them on 9-1/2's. 10 may be a bit too wide. Had 10's back in the day mounted on 295/50/15's with coil overs when it was stock and when it was cool for the tires to stick out a bit. Now everything needs to be tucked in properly like that loose shirt your mom always told you about lol.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #3 of 23 (permalink) Old Nov 7th, 17, 06:51 AM
mike
I am running 275-60-15's on 8" Cragars in the back Nitto drag radials, they recommend at least an 8" rim, looks great and only a slight rub due to the lowering springs. The rub is on the wheel lip molding I have been wanting to have them rolled or cut to stop the rubbing. I am 4.25 bs.
bigblockragtop is offline
post #4 of 23 (permalink) Old Nov 7th, 17, 01:28 PM Thread Starter
My 275's are on 8's now with no issues, just want to fill the wheel well more.
post #5 of 23 (permalink) Old Nov 7th, 17, 01:51 PM
9.5 would be safer and look the same imho....
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #6 of 23 (permalink) Old Nov 8th, 17, 03:10 AM
kevin
below is a picture of mine. it is old school and will stay that way.
it has 215-65-15s on 8" american racing wheels on the front with BB springs and an aluminum headed SB
the rear has 10" wheels with 295-50-15 with shackles in the first whole
69Z28 likes this.
flat tire is online now
post #7 of 23 (permalink) Old Nov 8th, 17, 04:48 AM
I have them on 8x15" Ansen sprints. No problems
67 RS/SS 350, M21, 3:70 POSI, Hooker side mount headers, blue dot tail lights. owner since 1974.
327fuelinjected is offline
post #8 of 23 (permalink) Old Nov 8th, 17, 01:51 PM Thread Starter
Thanks all....wheels I'm looking at don't offer 9 or 9.5
post #9 of 23 (permalink) Old Nov 8th, 17, 05:29 PM
Mickey
Moonpie's Avatar
I have 275/60/15's on 8 inch rims at the rear and have room to the shock mount for another skinny inch.
Moonpie is offline
post #10 of 23 (permalink) Old Nov 8th, 17, 05:37 PM Thread Starter
I do have 275/60's on 8" wide wheels now. I was looking at Billet Specialties and maybe going to a 10" wide wheel with the 275's like I see some in X275 class as well as some other
post #11 of 23 (permalink) Old Nov 8th, 17, 05:40 PM
Vega$69's Avatar
Im not seeing how a 10 will change the look of you using the same size tire. Tread width is a constant and the section width will not change more then a few mm.
Vega$69 is offline
post #12 of 23 (permalink) Old Nov 8th, 17, 05:49 PM Thread Starter
Really supposed to help in the traction department ???
Moonpie likes this.
post #13 of 23 (permalink) Old Nov 8th, 17, 05:50 PM
Vega$69's Avatar
What tires?
Vega$69 is offline
post #14 of 23 (permalink) Old Nov 8th, 17, 06:05 PM Thread Starter
Originally Posted by Vega$69 View Post
What tires?
Mickey ET Street R's
post #15 of 23 (permalink) Old Nov 8th, 17, 06:10 PM
Back in the day we would get pulled over for tires extending that far past the quarter. I used to run N50-15 tires.
