What I thought I knew... I didn't - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 14th, 17, 01:27 PM Thread Starter
All these years, I was convinced I had the 4 3/4" backspacing on my rear Centerlines... well turns out, I don't. After taking the rim off today to actually measure, it appears to be more like 3 3/8" which accounts for the tires sticking out past the fender more than I'd like. Am I correct to say that there are only two different backspacings for the 8.5" Autodrag wheel... one being 3 3/8" and another being 4 3/4"? If I am correct, does the 4 3/4" BS work well on a 67'? It appears that it would fit beautifully with a 275/60-15 tire. Can anyone confirm this?
Thanks, Jim
Name:	IMG_5209 - Copy.jpg
ID:	196714   Click image for larger version
Name:	IMG_5210 - Copy.jpg
No School Like The Old School!
67 RS 4 Speed with Big Block conversion
12 bolt with Richmond 3.90's
4Speed67CamaroRS is offline
post #2 of 3 (permalink) Old Nov 14th, 17, 01:48 PM
Re: What I thought I knew... I didn't
How did you measure ?
At 8.5" wide and only 3 3/8" BS... they would be much further out.
68 Camaro~LSx ~all motor
post #3 of 3 (permalink) Old Nov 14th, 17, 03:30 PM Thread Starter
I measured just like that but because the tire is mounted I had had to eyeball a bit and use a piece of wood that was only about a foot long so I couldn't go straight across... I had to cut the corner.
Thanks, Jim
