Rear sizing with DSE mini tubs - Team Camaro Tech
 2Likes
post #1 of 32 (permalink) Old Nov 23rd, 17, 07:00 AM Thread Starter
Apprentice
Chris
Thinking about mini tubing my stock supspension/ height 1967 Camaro. What would be the offset and width rim I could run. Any pics?
Merrozz572 is offline
post #2 of 32 (permalink) Old Nov 23rd, 17, 07:08 AM
Vega$69's Avatar
Re: Rear sizing with DSE mini tubs
Depends on your axle width.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 32 (permalink) Old Nov 23rd, 17, 07:10 AM
Wheel and tire sizes are here
https://www.detroitspeed.com/1967-19...mini-tubs.html
Backspacing/offset depends on rear end width.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 32 (permalink) Old Nov 23rd, 17, 07:40 PM Thread Starter
Apprentice
Chris
Thank you. As of right now I have a stock 10 posi on it
post #5 of 32 (permalink) Old Nov 24th, 17, 03:42 AM
Most guys who minitub also narrow the rear end. What is your plan?
dhutton is offline
post #6 of 32 (permalink) Old Nov 24th, 17, 05:20 AM
Chris
130fe's Avatar
I am running a stock width rear with 18x11.5s in the back and a 315 tire.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #7 of 32 (permalink) Old Nov 26th, 17, 05:32 AM
Greg
pittpens24's Avatar
Wow - you must have like a 8" BS then?
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #8 of 32 (permalink) Old Nov 26th, 17, 06:45 AM Thread Starter
Apprentice
Chris
Was planning on leaving it alone. Was hoping to get a 11.5” width in. Going to be ordering some custom forgelines just want to make sure I get the most for my money
post #9 of 32 (permalink) Old Nov 26th, 17, 06:55 AM
Vega$69's Avatar
I would also look at other manufactures of wheels. Forgeline are the Pro Tour Buzz word however substantially more expensive the other wheels with equal quality.
If you choose not to narrow you will have 7-8 inches or more back space and very little dish on the outside. May also complicate brakes, brake line and e-brake cable installations.
Vega$69 is offline
post #10 of 32 (permalink) Old Nov 26th, 17, 07:54 AM
Chris
130fe's Avatar
Post Re: Rear sizing with DSE mini tubs
Here are my wheel specs-
Front- 18x9 with 5.625" BS
Rear- 18x11.5 with 7.625" BS
These specs work great on my 68, stock subframe with Stock width rear. I was not concerned about the deep dish look in the rear.
Sure it does rub on the subframe when the wheel is turned ALL of the way (not concerned)
No issues with brakes, cables and such. I am running Boze Lateral-Gs. Love them with my C5 brakes. Running 265/315 tires. Will probably go to 275s up front on the next set and maybe go to 335s in rear.
Deangelo66 likes this.
Chris
130fe is offline
post #11 of 32 (permalink) Old Nov 26th, 17, 09:06 AM
Looks great. I am not a huge fan of the deep dish look. Yours will be easier on wheel bearings and should reduce pad knockback.
dhutton is offline
post #12 of 32 (permalink) Old Nov 26th, 17, 03:21 PM
Don, i am curious how you figure that offset is easier in the wheel bearings. Its about the same as a deep wheel, its just on the other side of the load center.
3d cad is offline
post #13 of 32 (permalink) Old Nov 26th, 17, 03:58 PM
I don’t think that is the case if you look way back at the bearing and not the wheel mounting surface. This phenomena has been known in pro-touring circles for quite some time. Guys with deep wheel lips generally suffer increased pad knockback....
Mandatory disclaimer: I have not performed a detailed analysis. Others have and this is what they have found. I am sure other will disagree and I have no issue with that....
Take a look at Stielow’s Hellfire. You’ll see similar offsets on a GM engineer’s car. No deep dish wheels there...
dhutton is offline
post #14 of 32 (permalink) Old Nov 26th, 17, 04:38 PM
That makes sense
3d cad is offline
post #15 of 32 (permalink) Old Nov 26th, 17, 04:42 PM
Vega$69's Avatar
I run 18x12 with my tubbed and narrowed Protour cars. With 6 1/2” BS.
Ran Wilwood 6 piston on one and C6ZO6 on another. F9 rear with big bearings.
Never experienced and issues with bearing or brakes.
Vega$69 is offline
