will these fit ? - Team Camaro Tech
 4Likes
post #1 of 53 (permalink) Old Jan 6th, 18, 02:58 PM Thread Starter
Steven
stamatisg1977's Avatar
will these fit ?
hey guys im looking into buying the wheels for my 69 coupe.
i just want to get a few opinions if the rims and tires that i like will fit the rear wheelwells without issue.
Ridler 650 B
18x9.5"
5.3" backspacing
275/35/18
the website says no issue but i would just like some human feedback from people i trust before i drop the hammer
thanks!!
ps here is the link to the set they offer different tire sizes i would like the 275's
https://www.rimsntires.com/package_t...wheelid=266822
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 53 (permalink) Old Jan 6th, 18, 03:17 PM
Brett
Re: will these fit ?
Your link only shows an 8" wide wheel fitting. No 9.5". My opinion those will not fit without cutting wheel wells. I tried it again and it does show 9.5 wide. I'm not sure. maybe someone will chime in with what wheels they have. Mine are stock.
Good luck.
Brett.....
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #3 of 53 (permalink) Old Jan 6th, 18, 03:37 PM Thread Starter
Steven
Good luck.
Brett.....
i chose staggered width
18x8 in front
18x9.5 in the rear
all options show width and backspacing. im going to measure clearances as soon as the temp outside gets above 10 degrees lol
Tremec TKO 600
post #4 of 53 (permalink) Old Jan 6th, 18, 03:39 PM
Brett
How do you like your 5-speed? I just ordered mine to replace my M-22.
Brett.....
post #5 of 53 (permalink) Old Jan 6th, 18, 03:44 PM Thread Starter
Steven
i love it. shifts real smooth too. just make sure to dial in that bellhousing.
Tremec TKO 600
post #6 of 53 (permalink) Old Jan 6th, 18, 05:00 PM
6D9
Ron
Its going to most likey rub even with trimmed wheel lips. Im running 10's wide with 275's...5.75" bs. Very tight . You could have the mount surface flat milled 1/4" to help get the fit proper. 5.5" is the norm for a 9.5"/275 combo.
69 Camaro
491/AFR 315'S/Straub hyd roller
TH400/GV OD
9" 3.50
6D9 is offline
post #7 of 53 (permalink) Old Jan 6th, 18, 05:10 PM
You will regret it imho. A lot of rubbing and/or trimming...
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #8 of 53 (permalink) Old Jan 7th, 18, 09:54 AM
Typically... the largest recommended size for a '69 with "stock" suspension is a 275/40-17 (or 18) on a 9.5" wide rear wheel with 5.5" backspace. Thats what I'm running, no rubbing while driving except when I make a turn into my pretty steep driveway and the rear tire on the inside rubs the 3" exhaust for a split second. I had the rear exhaust tubes modified to clear the 255-60-15's on 8" wheels but the new wheels obviously bring the tire bulge a little closer. Will probably have to re-do the tubes in the Spring. What makes mine a PITA is the 3" polished tips... getting them not to hit at the bend. It is very tight back there.
If you're running 2-1/4" or maybe even 2-1/2" tailpipes you might get away with it without rubbing. My car sits pretty low, so that also factors in to it. If your car is mini-tubbed... you might be OK with wider wheels and more backspace.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #9 of 53 (permalink) Old Jan 7th, 18, 11:15 AM Thread Starter
Steven
Im running a 4-link if that makes a difference
Tremec TKO 600
post #10 of 53 (permalink) Old Jan 7th, 18, 12:23 PM
6D9
Ron
Was looking at the website with the 650B's. They list the backspace at 5.25" for the 18x9.5's. Even a little less room. I would pass. Curious are your wheel well lips trimmed/rolled?
Here is my current Pro Touring set up.
IMG_20180102_185630_588 by ronfasano, on Flickr
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
post #11 of 53 (permalink) Old Jan 7th, 18, 12:43 PM
Not really. It is the wheel lips and tubs.
6D9 likes this.
post #12 of 53 (permalink) Old Jan 7th, 18, 01:06 PM Thread Starter
Steven
Wheel lips i can take care of. Shell is still in bodywork stage. I ordered a rim off of amazon. So if it dont fit there wont be any hassle in returning it
Tremec TKO 600
post #13 of 53 (permalink) Old Jan 7th, 18, 01:27 PM
6D9
Ron
They will take it back after mounting the tire?
69 Camaro
TH400/GV OD
9" 3.50
6D9 is offline
post #14 of 53 (permalink) Old Jan 7th, 18, 01:34 PM Thread Starter
Steven
Rim and tire seperate
Tremec TKO 600
post #15 of 53 (permalink) Old Jan 12th, 18, 02:16 PM Thread Starter
Steven
i mounted the wheel and took lots of measuring and comparisons to the wheel i took off.
it really looks like it will fit and the only trimming will be to the lip i took into account the tire face will stick out 1/8
' from the wheel lip.
i will do more thorough measurements tomorrow.
Tremec TKO 600
