18” Wheels 1969 Camaro Help - Team Camaro Tech
 2Likes
post #1 of 23 (permalink) Old Apr 12th, 18, 06:29 PM Thread Starter
Apprentice
Jordan
I have a 1969 Camaro lowered 2 inches in the front and back. I have purchased firestone firehawk 275/40r18 tires for the rear and 245/40r18 for the front. My wheels I had purchased were US Mags Rambler 18x8 with 4.5 backspacing +1.00mm offset on the front. 18x9.5 with 5.250 backspacing with +1.00mm offset. Ran into some issues today… The back wheels are going to rub the quarter panels and front wheels are going to rub the front fenders. Some proper info on backspacing and offset needed. I have disk brakes front and rear. Any information is helpful.
jrdnduvall is offline
post #2 of 23 (permalink) Old Apr 12th, 18, 07:26 PM
Chris
Re: 18” Wheels 1969 Camaro Help
If you're only missing clearance by a smidge, you could roll the fender inner lip to gain clearance.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #3 of 23 (permalink) Old Apr 12th, 18, 07:38 PM
Add some negative camber and the fronts will likely be ok. Try -.5 degrees.
Trimming the rear lip at the 10 and 2 o’clock positions usually helps.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #4 of 23 (permalink) Old Apr 12th, 18, 07:40 PM Thread Starter
Apprentice
Jordan
I suggested that to the body shop and they steered me away from that. Going to need new wheels anyway as the others were ruined by the tire shop, but that’s a story for another day… Any info on correct backspace and sizing?
post #5 of 23 (permalink) Old Apr 13th, 18, 05:17 AM
Bill
every vehicle is a little different so everyone's specs do not always work out for you, ask me how I know. I had to change tire size , the tire shop went to test fit , they would not fit and charged me a small fee to change tires to a smaller size before driving on them.
bills69 is offline
post #6 of 23 (permalink) Old Apr 13th, 18, 05:43 AM
+6mm offset front and rear assuming your disc brakes have not affected it. Use the wheels you already have to confirm this. Camber plays an important role on front tire fit. You need to know what camber you have when doing your test fitting.
Relying on a body shop to optimize wheel and tire fit is a little odd imho....
dhutton is offline
post #7 of 23 (permalink) Old Apr 13th, 18, 06:54 AM
Vega$69's Avatar
to correctly determine wheel spec you have to start with the tire. Section width and tread width.
You can also start by installing a wheel with a known/measured BS without the tire mounted. Jack stand under the axle and take relative comparison measurements with straight edge clamp to the wheel.
When it's close go with slightly more then calculated BS. You can always ad an 1/8" or 1/4" spacer to move the wheel outward.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #8 of 23 (permalink) Old Apr 13th, 18, 07:24 AM
Simon
I went with 235/40/18 in the fronts, try button head bolts to help gain clearance. Also have the shop put one of the front wheels with the tire mounted on the back and take the critical measurements before purchasing and mounting the rest. If I'm not mistaken my shop had to reverse mount the tires onto the rims.
slazisme is offline
post #9 of 23 (permalink) Old Apr 13th, 18, 10:18 AM
+6mm offset keeps the wheel centered in the opening regardless of width....
dhutton is offline
post #10 of 23 (permalink) Old Apr 13th, 18, 11:14 AM
Robert
I have Budnik Vapor wheels. Charcoal Grey centers with polished rims.
18x8 5" BS - 245/45-18
18x9 5.375" BS - 275/40-18
My car is lowered 1.5" in the rear, the front is probably 2 inches down from sagging springs. I have new 2" drop springs to install soon.
Both front and back fit without modifying the lips, I have about 1/2" clearance. BUT, I do have slight rubbing on the frame in the rear going over bumps going around a corner at low speed and I cannot turn as sharp. The turning issue might be straightened out once I install RideTech upper control arms and get a good alignment, we will see. I have pictures here:
https://www.camaros.net/forums/33-cam...s-evening.html
Cunning69 is offline
post #11 of 23 (permalink) Old Apr 13th, 18, 06:36 PM
Beth
As Don said, 6mm puts you in the center.
On an 8" wheel, add 1" to get the outer width, divide by 2 to get the center.
8"+1"= 9"/2= 4.5" + 6mm (1/4") offset to the inside = 4.75" ideal backspace for an 8" rim
I bought 4.5" backspace wheels for my car because they are easier to find and I wasn't trying to squeeze in the largest possible tire.
NashvilleCat is offline
post #12 of 23 (permalink) Old Apr 15th, 18, 04:19 PM Thread Starter
Apprentice
Jordan
Here's my plan after some measuring. Im going to buy U425 Rambler wheels from US Mags. They are customizable. In the rear I'm going to go with a 18x9 wheel with 5.75 backspace. For the front I'm going to go with a 18x8 with a 5.50 offset. Does this seem like too much backspacing for the front? I'm erring on the side of too much as I could add a spacer if needed. I appreciate everyones advice thus far.
post #13 of 23 (permalink) Old Apr 15th, 18, 04:38 PM
Your spacers may be so thick that the wheel studs are not long enough. 5.5 offset or backspacing?
+6mm offset centers the wheel. Translate this to backspacing for a given wheel width using this tool:
https://rimsntires.com/specspro.jsp
dhutton is offline
post #14 of 23 (permalink) Old Apr 15th, 18, 05:46 PM Thread Starter
Apprentice
Jordan
Attached are my results with a 6mm offset. The original wheel is the one I had before vs the one I'm thinking of ordering. The result is a bit confusing to me. Just have a hard time understanding all this.
ID:	211833   Click image for larger version
post #15 of 23 (permalink) Old Apr 15th, 18, 06:12 PM
Yep, you needed another .25” of backspacing with your original wheels. That is why I suggested trimming the rear wheel lips and adding negative camber on the front.
Offset is measured relative to the center of the wheel so it is independent of wheel width.
A 275 tire will likely rub under some conditions no matter what you do but it is minimal and most who want to run a 275 tire choose to live with it. Usually when approaching a steep driveway at an angle.
dhutton is offline
