4.5 Backspace - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 16th, 18, 08:27 AM Thread Starter
Probationer
4.5 Backspace
New forum member here with another backspace question that has probably been asked ad nauseam. I really want to run 18" Foose Legends (gloss black) on a '69. The rear should be no problem from everything I've read; 18x9 with 5.25 BS and 275 40 18s. The front is the issue. I know on an 18x8 4.75 bs is the consensus for optimum fit using 245 40 18s. The Foose only comes in 4.5 bs. 1/4" difference. If I change the tires to a 235 40 18 the difference should about equal out correct? I could even drop the tire to a 225 40 18 to gain a little extra but am hoping the 235 will be a good fit and not have fender rub issues. And yes, my wife is pretty set on these wheels...it's technically her car...technically ;-). Thanks in advance.
EEYORE is offline
post #2 of 5 (permalink) Old Jun 16th, 18, 09:07 AM
Beth
Re: 4.5 Backspace
Yes I agree with your math. I went with 225's on the front because I'm not an auto-crosser :-)
You might have to install button-head screws but probably not. I think you will be fine
NashvilleCat is offline
post #3 of 5 (permalink) Old Jun 16th, 18, 09:18 AM Thread Starter
Probationer
Re: 4.5 Backspace
Thanks. Always good to have another set of eyes/ears when problem solving.
EEYORE is offline
post #4 of 5 (permalink) Old Jun 18th, 18, 07:41 AM
Probationer
Discount Tire
Re: 4.5 Backspace
Hi EEYORE, I agree with you and NashvilleCat. You should have no issues running that 4.5 BS wheel on the front of your car. As far as the tire sizes, the 235 40 18 size will be 1.25" shorter overall than the 275 40 18, which works if you are wanting a bit of a raked look. If you are wanting a more level stance, you may want to look at a 235 45 18. That size would be less than 1/2" shorter than the rear tire size.
Discount Tire is offline
post #5 of 5 (permalink) Old Jun 18th, 18, 08:52 AM
DjD
DjD's Avatar
Re: 4.5 Backspace
18 x 8 4.75bs is a +6 offset and 4.5bs is a 0 (zero) offset. That 1/4" difference is all outward and is a big deal on a '69 with the squared off wheel well depending on how low your front end sits.
I would re-think wheel size and see if you can get an 18x7 4.25bs (+6 offset) and keep your tire and wheel centered in the wheel cavity. You will most likely need button head fender bolts and a bit of an alignment change (some negative camber) with a +6 offset but you can run the larger tire with less issue than the smaller tire at zero offset. Again a lot of this depends on how low your front sits...
...Dennis
DjD is offline
