Spacer Kits - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 7th, 18, 11:39 AM Thread Starter
Probationer
Spacer Kits
Due to the narrowness of the front tires that were placed on the car before I got it, the tires rub on a hard turn and aesthetically don't sit out right. Would like to step them out about an inch and a half to cure both issues but not sure of the best route to take or the best brands for this car. It's an 89 camaro.
zap9112000 is offline
post #2 of 4 (permalink) Old Jul 7th, 18, 11:54 AM
Steven
stamatisg1977's Avatar
Re: Spacer Kits
going out 1-1/2" is kind of dangerous. also you will need longer wheel studs
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 4 (permalink) Old Jul 8th, 18, 05:52 AM Thread Starter
Probationer
That's what I was worried about. Guessing I'm just going to have to change wheels out completely to get get a wider tire. Thanks
post #4 of 4 (permalink) Old Jul 8th, 18, 05:35 PM
mike
Re: Spacer Kits
You can keep the tires if you like them but just get the proper offset rim.
bigblockragtop is offline
