Front tire rub 67 Camero - Team Camaro Tech
 5Likes
  • 1 Post By Gbauer
  • 1 Post By stinger67
  • 3 Post By dhutton
post #1 of 10 (permalink) Old Jul 11th, 18, 07:51 AM Thread Starter
Probationer
I just restored my 67 Camero. I installed disc brakes with 2” drop spindles and installed 225/50/17 tires. Now tires rubbing outside wheel well when hit bumps. Anyone experienced and how fixed?
Butch’s67camero is offline
post #2 of 10 (permalink) Old Jul 11th, 18, 08:09 AM
George
Gbauer's Avatar
Re: Front tire rub 67 Camero
First off go back to the regular spindles and either cut a coil out of the stock springs or get lowering springs. Drop spindles always screw up your suspension geometry on these cars despite what the manufacturers tell you. I fought mine for a full year before giving up and going back to stock spindles with cut springs. Just do one coil at a time and drive it for a bit before cutting another. One will likely get you the ride height you want.
Secondly: it's likely rubbing on the bolt heads just inside your fender (feel around and you'll find them). I, and others, installed button head bolts and if the rub is slight it'll likely go away with that fix.
I don't recall the thread or bolt length but that should be easy to figure out if you remove one of the existing bolts.
130fe likes this.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #3 of 10 (permalink) Old Jul 11th, 18, 09:03 AM
kevin
not to be a smart ***, but when you lower and put bigger tires on what did you expect
flat tire is offline
post #4 of 10 (permalink) Old Jul 11th, 18, 10:11 AM
Get an alignment. Target -.5 to -.75 deg of camber and 3 to 5 deg caster. Will make a big difference. Do not use factory alignment specs, you need negative camber, not positive....
Bolt thread is 5/16-18. You can find buttonhead bolts on eBay.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #5 of 10 (permalink) Old Jul 11th, 18, 10:22 AM
Jeff
If you changed from drum brakes to disc, that moves your wheel outward.
Thanks,
Jeff
1968 Camaro
Chevy68 is offline
post #6 of 10 (permalink) Old Jul 11th, 18, 02:57 PM
Apprentice
Also, Your 225/50-17 tire is very similar in diameter to my 215/65-15 (other than 0.4" wider) which seem to be working fine in what little driving I've done thus far. I also have disc brakes. This may be obvious, but I'll type it anyway, likely the wheel offset or back spacing is placing the tire to far outward. Just another variable to consider.
67 purchased June 2018 / frame off resto in 2015 / sold at Mecum in Austin TX Dec 2015 / 350 (unknown internals) / TH350 / Edelbrock aluminum heads and intake / Hooker long tubes, Flowmasters / power front disc brakes / PS
JLowe is offline
post #7 of 10 (permalink) Old Jul 11th, 18, 05:18 PM
Beth
Agree. I bet your wheels are 8" wide with the 225 tire so backspace should be 4.5" to 4.75".
7" wheels should be 4" to 4.25" backspace
NashvilleCat is offline
post #8 of 10 (permalink) Old Jul 13th, 18, 07:52 PM
Craig
I just installed Budnik 17 x 8 on my 67 which is lowered a couple of inches. They have 4 7/8 backspace with 235 45 tires. I tried 245 but like the 235 better as I also did the guilstrand upper control arm relocation which moves tire back towards inner fender. No tire rub with either tire. Went with 17 x 9 inch in rear with 275 40
Agitator is offline
post #9 of 10 (permalink) Old Jul 14th, 18, 05:04 PM
Chris
stinger67's Avatar
Do we put ne members / probationers on any sort of double secret probation for spelling Camaro with an "e"?
68 Cowboy likes this.
stinger67 is offline
post #10 of 10 (permalink) Old Jul 14th, 18, 05:17 PM
He has not been back since his first post. I am guessing he is trying to log into cameros.net
Gbauer, stinger67 and 68 Cowboy like this.
dhutton is offline
