Wheel rubbing - Team Camaro Tech
post #1 of 16 (permalink) Old Jul 19th, 18, 05:30 PM Thread Starter
Apprentice
Andrew
Wheel rubbing
Hi guys I’m sure this topic has already been discussed but I was wondering what everyone’s running for rear tires. The ‘67 I just bought has N50-15 on the rear and I’m getting massive rubbing problems I want to throw a smaller tire on the back and was looking for suggestions. I’m looking to keep the 15” rim size I just want to be able to drive around safe and worry free. What do you guys think would be a good fit and still look mean?
Andrew25dean is offline
post #2 of 16 (permalink) Old Jul 19th, 18, 05:40 PM
Re: Wheel rubbing
What is the width and backspacing of your wheels?
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 16 (permalink) Old Jul 19th, 18, 06:04 PM
scblucam's Avatar
Re: Wheel rubbing
An N50 15 will stick out of the fender by at least 2". To run them you have to have serious coil overs or air shock and still may rub on a serious bump.
68 302 M20 - 85 IROC Z
scblucam is offline
post #4 of 16 (permalink) Old Jul 19th, 18, 07:57 PM Thread Starter
Apprentice
Andrew
Honestly not sure what the backspace is but I’m open to rim and tire set up suggestions
post #5 of 16 (permalink) Old Jul 20th, 18, 03:51 AM
Re: Wheel rubbing
You need to figure it out, especially if your goal is to go wider than stock.
3d cad is offline
post #6 of 16 (permalink) Old Jul 20th, 18, 02:39 PM
Garth
Re: Wheel rubbing
15x8 wheel with 4.5" BS and 255/60 tire is pretty common on 67/8's. I haven't had any rubbing issues, but haven't driven it much. It looks borderline as you can see. Do you still have mono-leaf springs ? May be time for an upgrade if you're gonna run a borderline size tire.
Garfields Maro is offline
post #7 of 16 (permalink) Old Jul 20th, 18, 02:48 PM Thread Starter
Apprentice
Andrew
I do still have the mono leaf set up with rear drums is there a standard set up that I can keep the mono leafs but still have a decent tire?
post #8 of 16 (permalink) Old Jul 20th, 18, 02:54 PM
Garth
Re: Wheel rubbing
I think you'd be alright with a 245/60 tire. Same wheel I described above. OR air shocks, which I don't recommend, as it'll ride like a truck, imo.
post #9 of 16 (permalink) Old Jul 20th, 18, 03:07 PM Thread Starter
Apprentice
Andrew
Thanks a lot I’ll look into switching to a 245/60 the N50s are way over kill and just kinda look ridiculous on a car with no performance upgrades besides a new carb
post #10 of 16 (permalink) Old Jul 20th, 18, 03:11 PM
Garth
Re: Wheel rubbing
You're welcome. Check your backspace, unless you plan on new wheels....https://www.rsracing.com/TechWheel.aspx#backspace
post #11 of 16 (permalink) Old Jul 20th, 18, 03:17 PM
Re: Wheel rubbing
Garth, does your wife allow you to park your car inside on the carpet. Man, you have a great wife. Mine has to be parked in the garage
1967 RS/SS Vert (non matching)
aggiegoalie is offline
post #12 of 16 (permalink) Old Jul 20th, 18, 03:24 PM Thread Starter
Apprentice
Andrew
I’ll take a look at the backspace and rim width on Sunday and post the dimensions they’re Cragar super sports I’m just hoping they’re small enough to get a 235-245 on there with out an issue. I’ll post to the same thread thanks for the help!
post #13 of 16 (permalink) Old Jul 20th, 18, 03:47 PM
Darin
ilikeike's Avatar
Although I run 18” rims, I run a 235 on front and 275 on back, stock tubs no rubbing.
I would think a 235 or 245 on back would be a little skinny. A 265 min would probably look good and have plenty of room.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #14 of 16 (permalink) Old Jul 20th, 18, 04:07 PM Thread Starter
Apprentice
Andrew
265 even with a mono leaf set up? I drive in a place with some serious potholes. Would you suggest 265/60R15?
post #15 of 16 (permalink) Old Jul 20th, 18, 04:10 PM Thread Starter
Apprentice
Andrew
Also Garfield out of curiosity what rims are those they look gorgeous
