Corvette Rims on a 69 Camaro - Team Camaro Tech
post #1 of 10 (permalink) Old Sep 2nd, 18, 04:13 PM Thread Starter
Vic
Hi, I am looking to put 2009 corvette rims or the 2006 c6 5 stars on the 1969 Camaro. I have a stock 12 bolt rear, dse mini tub kit that include the 2” offset shackles for the leafs, and a wilwood disc brake conversion with drum parking brake. I have heard I need a 2” spacer but haven’t found anything that’ll help me figure out whether I can just bolt and go. Wheels are staggered and would be front 245/40/18 and back 285/35/19.
Vic
1969 Camaro SS
Camaro1969 is offline
post #2 of 10 (permalink) Old Sep 2nd, 18, 04:25 PM Thread Starter
Vic
Rim pictures attached. Note I would like the option of putting any c6 rims on, even z06 as my mini tub allows 335.
https://drive.google.com/open?id=16J...0KafmvzvSZN5r2
Vic
1969 Camaro SS
post #3 of 10 (permalink) Old Sep 2nd, 18, 05:18 PM
DjD
DjD's Avatar
Re: Corvette Rims on a 69 Camaro
Wheels width and backspacing (or offset) would really help...
...Dennis
DjD is offline
post #4 of 10 (permalink) Old Sep 2nd, 18, 05:27 PM
You cannot bolt C6 wheels on a 69 Camaro and go. Spacers are needed.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #5 of 10 (permalink) Old Sep 2nd, 18, 08:16 PM Thread Starter
Vic
Hi djd, wheel size is in the post, the offset I don’t have for the wheel. The tears are 19x10 GM 09596785 to help you know the style of rim..
Vic
1969 Camaro SS
post #6 of 10 (permalink) Old Sep 2nd, 18, 08:17 PM Thread Starter
Vic
Hi don, the spacer pushes the rim outward? Is it because it’ll hit the leafs? Even with a DSE mini tub kit?
Vic
1969 Camaro SS
post #7 of 10 (permalink) Old Sep 3rd, 18, 03:42 AM
The backspacing is too much. Even if it didnít hit the leafs it wonít look right because the wheel is too far into the wheel well. Fronts wonít work either.
Wheel specs are here:
http://image.mamotorworksmedia.com/p...ence_Guide.pdf
dhutton is offline
post #8 of 10 (permalink) Old Sep 3rd, 18, 06:03 AM
Beth
Vic,
I think Mike Kelcy has used these wheels on his Camaro.
Contact him here :
https://www.camaros.net/forums/priva...=newpm&u=10278
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #9 of 10 (permalink) Old Sep 3rd, 18, 06:13 AM
Originally Posted by NashvilleCat View Post
Vic,
Contact him here :
Yes he did with 2Ē spacers. More info here:
https://www.camaros.net/forums/17-wh...o-17-18-a.html
dhutton is offline
post #10 of 10 (permalink) Old Sep 3rd, 18, 11:40 AM
DjD
DjD's Avatar
Originally Posted by Camaro1969 View Post
Hi djd, wheel size is in the post, the offset I donít have for the wheel. The tears are 19x10 GM 09596785 to help you know the style of rim..
Those are tire sizes in your first post, you just gave me the wheel size (19x10). On a stock rear end you would fit 5.75" of backspacing, your mini tubs and shackle move should allow you as much as 7.75" and if your wheel has more bs than that you will need an adapter to make up the difference.
...Dennis
DjD is offline
