69 Convert Rims/Tires - Team Camaro Tech
post #1 of 9 (permalink) Old Oct 10th, 18, 10:03 AM Thread Starter
davidmar's Avatar
Been doing a ton of research on some rims and tires for my 69 Convert. There is almost too much info on what size rim, back spacing etc. Can anyone comment if they have a similar set-up on what I am planning on purchasing?
Classic Torq Thrust II 17x8 (Front) & 17x9.5 (Rear) 5x4.75 Package
Front Tire Option: 225/45R17 BFG Sport Comp-2
Rear Tire Option: 275/40R17 BFG Sport Comp-2
Bolt Pattern:5x120.65 (5x4.75)
Offset:+8mm
Backspace:4.81" (Front), 5.50" (Rear)
Hub Bore:83.06mm
Thank you-DM
69 Camaro Convertible - Undergoing frame off restoration.
davidmar is offline
post #2 of 9 (permalink) Old Oct 11th, 18, 04:44 AM
Bruce
Re: 69 Convert Rims/Tires
Did the same with Foose Knuckle except 255 on the rear to keep it more "original" and the car was lowered 2". All 4 wheels are 8".
The Camaro Guy is offline
post #3 of 9 (permalink) Old Oct 11th, 18, 08:27 AM
Bill
255 on rear here
bills69 is offline
post #4 of 9 (permalink) Old Oct 11th, 18, 09:28 PM
69z28freak's Avatar
I am looking at running Torque Thrust 8.5x15 with 255/60 BFG's on the rear. Any issues with rubbing with that combo?
Grandma, 69.5, Z/28 Finally Done! Well almost...
My Build Thread
69z28freak is offline
post #5 of 9 (permalink) Old Oct 12th, 18, 05:12 AM
Andrew
Andrew69's Avatar
Respect these backspace specs with any diameter of wheel and you should be good.
Front 16 x 7 w/ 4" backspace 225/55 tires
Rear 16 x 8 w/ 4-3/4 backspace 255/50 tires
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #6 of 9 (permalink) Old Oct 12th, 18, 12:49 PM
DjD
DjD's Avatar
The key on a 1st gen and maybe more so on a '69 because of the flat top wheel opening is a +6 offset. The +6 will center the wheel in the well if the wheel mounting is in the stock factory position. + size disc brake conversions usually move the wheel mounting pad outboard some so keep that in mind when fitting your wheels and tires...
...Dennis
DjD is offline
post #7 of 9 (permalink) Old Oct 12th, 18, 02:33 PM
DT
Donny
DT's Avatar
I have this on my 69 vert. 17x8 (Front) & 17x9.5 (Rear) 5x4.75 My rear is a 255 though. I used Dennis' tire combo.
DT is offline
post #8 of 9 (permalink) Old Oct 12th, 18, 07:12 PM
Chris
ckaram's Avatar
On my 68 convert fronts are 17x7, 4" BS on 235/45's. Rears are 17x8, 4.5" BS on 255/45's.
Check my rides:
1968 Camaro Convertible LS1, T56
2016 Challenger RT Scat Pack Shaker
ckaram is offline
post #9 of 9 (permalink) Old Oct 13th, 18, 06:00 AM
Bill
x2 as Dennis and Donny
bills69 is offline
