Tire size with mini tubs - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 21st, 18, 08:08 AM Thread Starter
Frank
I know it's been beat to death but ....
What;s the biggest you've stuffed under a '68 Camaro with mini tubs? I'm going with the TCI Torque arm/coil over set up and the fender lips have been rolled. Would like to stay with 18's but not opposed to 17's
What do you have for tire size, back spacing etc..
'68 Camaro 454, 4sp
Just 1 More is offline
post #2 of 7 (permalink) Old Oct 21st, 18, 08:29 AM
Re: Tire size with mini tubs
275's fit great in a stock wheel well on 15 x 8's with 4.5" BS....Sssssooooo, I would hazard a guess that a 2" mini tub would move that 2" in making that 6.5" BS and a 315 tire on a 10" wheel ?
68 Camaro~LSx ~all motor
post #3 of 7 (permalink) Old Oct 21st, 18, 02:17 PM
Chris
130fe's Avatar
315s work well on an 11 wheel in a 67/68. I have 315/30-18 on mine.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is online now
post #4 of 7 (permalink) Old Oct 21st, 18, 02:26 PM
From the Detroit Speed website:
The Detroit Speed, Inc. Mini-Tubs are inner wheel housings designed to accommodate wider tire and wheel packages, including tires as wide as 315mm (1967-1968 F-Body) and 335mm (1969 F-Body).
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #5 of 7 (permalink) Old Oct 21st, 18, 05:11 PM
Vega$69's Avatar
I ran 335/18s on my mini tubbed 69 with TCI torque arm
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #6 of 7 (permalink) Old Oct 21st, 18, 05:14 PM
Chris
stinger67's Avatar
315 40 18s with 18 x 11s with my DSE minitubs on my 67
The rear end is narrowed a few inches too.
I might be able to squeeze a touch more in.
stinger67 is offline
post #7 of 7 (permalink) Old Oct 22nd, 18, 03:24 AM
Greg
pittpens24's Avatar
I fit 335/18's on my "68, but I also sectioned my rear frame rail.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is online now
