Ordering Wheels for my 69 - Team Camaro Tech
post #1 of 9 (permalink) Old Nov 17th, 18, 05:30 AM Thread Starter
Planning on ordering wheels for my 69 this week. Researched this extensively and wanted to share before I made the purchase.
For the fronts I am planning to go with 17x8” with 4.75BS and 235/45/17 tire. I have a stock subframe with ridetech upper and lower control arms and coil overs. This should put my wheel height at 25.3” high. I notice majority of people use 4.75BS but some rain 5” BS. Which is better for my set up?
Out back I plan to run an 17x11” wide wheel and either a 295/35/17 which would put me at 25.1” tall or a 315/35/17 which is 25.7” tall. I would think that either of these would match the front pretty good?? Thoughts? Back is mini-tubbed with ridetech 4 link.
Thanks!
1969 Camaro ProTouring build
350 Tuned port, 700R4
Moser 12 bolt
mini-tubbed - resto in progress; painted fall of 2018
1969 Camaro X-55
350 4 speed, black with white hockey stripe
White interior
Completed resto in 2018
Prosconst is offline
post #2 of 9 (permalink) Old Nov 17th, 18, 05:40 AM
Re: Ordering Wheels for my 69
Rear tire should always be taller and have more sidewall than the front.
I think the car will push with 315 rear and 235 front. Try to get more tire up front. At least 245...
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 9 (permalink) Old Nov 17th, 18, 09:10 AM Thread Starter
If I go with a 245/45/17 front will the 4.75BS still work on a 17x8” wheel? That looks like it will increase the tire height to 25.7” in the front
Moser 12 bolt
1969 Camaro X-55
White interior
post #4 of 9 (permalink) Old Nov 17th, 18, 09:19 AM
I would look at a 40 series tire for the front. I generally offset series front to rear by 5. Backspacing should be more or less independent of wheel width if you centered the wheel in the well.
dhutton is offline
post #5 of 9 (permalink) Old Nov 20th, 18, 10:25 AM Thread Starter
Narrowed it down to these 2 sizes. I’m not crazy about 18” in the front but that may be the better option.
235/45R17 Front and 305/35R18 rear, height will be 25.3 front and 26.41 rear
Or
245/40R18 Front and 295/35R18 Rear heights will be 25.7” front and 26.1” rear
Originally I wanted to go with 17” all the way around but it seems that not many rear tires are available for 17” anymore
Moser 12 bolt
1969 Camaro X-55
White interior
post #6 of 9 (permalink) Old Nov 20th, 18, 10:50 AM
Second option is much better imho but I would go at least 315.
dhutton is offline
post #7 of 9 (permalink) Old Nov 20th, 18, 11:09 AM Thread Starter
I wanted a 315 or a 305 but they aren’t manufactured. The only street tire available that I can find is a 315/30R18 which is only 25.4” tall and 3.7” sidewall height which would be lower than the front....frustrating!
Moser 12 bolt
1969 Camaro X-55
White interior
post #8 of 9 (permalink) Old Nov 20th, 18, 02:15 PM
Check 30 series rear and 35 series front. Keep that separation of 5.
dhutton is offline
post #9 of 9 (permalink) Old Nov 20th, 18, 02:55 PM
Darin
ilikeike's Avatar
I had the same issues trying to find a tire combo that had a touch more sidewall in back.
I needed a 275 in back so I used a 275/35/18 25.6" tall (Bridgestone RE71R) They did not have a 40 or 45 in an 18".
I wanted a 245 in front but it was to tall at 25.7" so I had to settle for a 235/40/18 at 25.4" tall.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
