Tire size help for 68 camaro -Stock wheel well- - Team Camaro Tech
post #1 of 18 (permalink) Old Nov 21st, 18, 05:32 PM Thread Starter
Probationer
Hey guys, I just got a 68 camaro to build up this winter. I am wondering if 15x8 wheels with 4.25" backspacing will fit in the stock wheel well with 275/60 Radial T/A's. As far as I know the back springs are stock. I have heard that a 15x8 with 4.5" bs will fit with a 275/60, and I would like to know if the 1/4" difference will affect it. And what would be an ideal front wheel size for a 225/60 tire?
cMazel is offline
post #2 of 18 (permalink) Old Nov 21st, 18, 05:47 PM
Re: Tire size help for 68 camaro -Stock wheel well-
15x8 w/ 4.5 BS is about perfect....clears all around.
68 Camaro~LSx ~all motor
post #3 of 18 (permalink) Old Nov 21st, 18, 05:55 PM
Pete
Your first problem is the rims are way too narrow for those size tires. A 275 has over 11 inches of tread. Your rims should be within a half inch of your tire size. While the 15x8 would fit in the rear with the backspacing (they are +6 offset), I doubt the tires would and you'll end up with tires that are way higher in the center than the outer tread because of the width difference. A 225 front tire is about 9 inches wide so an 8.5" rim is minimum I would go. I have 235/45R17s on all 4 corners. They are just about stock height, but with a +0 offset barely clear the rear fenders.
68lowered is offline
post #4 of 18 (permalink) Old Nov 21st, 18, 06:44 PM Thread Starter
Probationer
Doug, I have been following your build to base my tire size off of because I love the look of your car. Do you think that 1/4" bs difference would make them not fit?
cMazel is offline
post #5 of 18 (permalink) Old Nov 21st, 18, 06:47 PM Thread Starter
Probationer
Thanks for the advice. I have only really been working on Japanese cars so these different diameters and widths are new to me. And I have seen Doug as well as others say that that 275/60's are perfect on 8" wide wheels so now I am conflicted
cMazel is offline
post #6 of 18 (permalink) Old Nov 21st, 18, 08:18 PM
I feel you on the conflict. I have 245/60's on 15x8's right now and want to upgrade to 275/60's (or maybe /50's). The 8" rim does seem narrow. However, for the 275/60, an 8" rim is the measuring wheel width. It is on the lower end of the width range recommended though which is kind of weird. I've seen plenty of guys like Doug say they work. You'll just have more sidewall bulge I guess. I have rally wheels and there's nothing in between 8" and 10" wide. At 10" they start to extend past the fender with stock wheel wells/suspension if that's a concern. I test fit some 295/50's on 15x10's and they rubbed slightly on the inner wheel well. Wish they made 9's..
Please post pics when you decide what to get.
Doug, do you have pics from other angles you could post? What size do you have up front?
SOAR B-1 is offline
post #7 of 18 (permalink) Old Nov 21st, 18, 11:00 PM
Sean
Ditto, I run essentially the same set up as Doug, only on 15x8 rally wheels. Its tight, but fits. A 1/4 may not matter, but I would say its going to rub at some point.
Sean
Franklin D. Roosevelt
68rs406 is offline
post #8 of 18 (permalink) Old Nov 22nd, 18, 12:12 AM
Garth
There's always a bit conflict. 255/60 on 15x8, 4.5bs. Hard to believe a 275 doesn't rub. Depends on the suspension and/or wheel well mods..
On the front, 15x7 4.25bs is ideal for a 225/60 or 215/65. Any size wider tire is borderline. Some folks claim a 235/60 won't rub, so again depends on the suspension I guess.
Garfields Maro is online now
post #9 of 18 (permalink) Old Nov 22nd, 18, 02:32 AM
kevin
here is a picture of my 68 with 10" -4.5 back space American racing wheels with 295-50-15 . it has 5 spring leaves. the tire does stick out 1.5" beyond the fender
I also use jagger brothers clip on mud flaps. it also still retains the original BB front springs holding an aluminum headed SB
flat tire is offline
post #10 of 18 (permalink) Old Nov 22nd, 18, 03:46 AM
Most pics locked up on PB mess...BUT, IF I place a straight edge on my tire to the lip....it is MAYBE a 1/4" gap, so it MAY rub with a 4.25 BS wheel. If you rolled the lip then its not an issue anymore.
Now also remember...your real axle does shift slightly left/right in hard turns.(as well as tire flex)
Up front are some skinnies...205/65/15 on 5" wheels with 2.5" BS....so not much help there
I had some McCreay 285/60/15 SH on there at one time. They were flush with the wheel well and rubbed on bumps/turns....so they had to go (on same wheels)
see bottom of post....
MT recommends....
Minimum Recommended Wheel Width: 7.50 in.
Maximum Recommended Wheel Width: 9.50 in.
But I know the 275x guys run them on wider wheels
Name:	285 60's 005.jpg
ID:	222935   Click image for larger version
Name:	285 60's 006.jpg
post #11 of 18 (permalink) Old Nov 22nd, 18, 07:11 AM Thread Starter
Probationer
Thanks everyone! Lots of good information and great looking cars. Soar B-1, I will post pictures on here when I get the wheels on there, but it might be a while (Reworking the whole interior/engine first). Garfields, thanks for the front tire info. I think I will go with 15x8 4.5” bs on the back with 275/60’s just to be safe based on Doug’s measurements. 15x7 4.25” bs 225/60’s up front. Now to decide on wheels...
cMazel is offline
post #12 of 18 (permalink) Old Nov 22nd, 18, 08:52 AM
Thanks everyone! Lots of good information and great looking cars. Soar B-1, I will post pictures on here when I get the wheels on there, but it might be a while (Reworking the whole interior/engine first). Garfields, thanks for the front tire info. I think I will go with 15x8 4.5 bs on the back with 275/60s just to be safe based on Dougs measurements. 15x7 4.25 bs 225/60s up front. Now to decide on wheels...
Rough measurements....
11" from inner wheel well to quarter lip
6" from drum face to inner wheel well
5" from drum face to quarter lip
Based off memory....
post #13 of 18 (permalink) Old Nov 22nd, 18, 01:03 PM
Darin
ilikeike's Avatar
I run a 275 with 3” drop springs.
No issues.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #14 of 18 (permalink) Old Nov 22nd, 18, 01:43 PM Thread Starter
Probationer
Based off memory....<img src="https://www.camaros.net/forums/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" />
Sounds great. Thanks again.
cMazel is offline
post #15 of 18 (permalink) Old Nov 22nd, 18, 01:44 PM Thread Starter
Probationer
No issues.
Perfect, what wheels do you run?
cMazel is offline
