Can not remove rally rings - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 2nd, 19, 08:41 PM Thread Starter
Apprentice
Chris
Hello all,
67 camaro, 15x7 rallys
I read and searched,,, I have removed these in the past, but apparently something is seized or changed since i last owned this car 30 years ago.
I can not for the life of me remove the rings. I have pulled, tugged, pried. Nada, zip.
Not sure if they have been replaced with knockoff junk but they are on there.
Any advice before i ruin them.... All four are are on like someone glued them into place.
Center caps popped right off.
Chris
chris3353 is offline
post #2 of 6 (permalink) Old Apr 3rd, 19, 05:41 AM
Chris
re: Can not remove rally rings
You're going to have to just pry them off with a long tire iron. If necessary you could get a long steel rod and grind one end to a chisel point for more leverage. A small block of wood between the pry bar and the tire would help. Mine were particularly hard to remove too and this worked for me.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #3 of 6 (permalink) Old Apr 3rd, 19, 08:35 AM
Some trim rings had 4 or 5 clips rather than teeth. Look close to see what you have.
The rings with clips can be a bitch to remove and install. You could try a penetrating
fluid.
my 67' build thread:
allanjs is offline
post #4 of 6 (permalink) Old Apr 3rd, 19, 05:48 PM
If you have originals with four clips, locate the clips and put a large screwdriver in the center, hit the screwdriver with your hand. The clip is spring steel and will come loose. Repeat three more times.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
nashcar is offline
post #5 of 6 (permalink) Old Apr 4th, 19, 07:15 AM
Fred
77thor's Avatar
Re: Can not remove rally rings
I had a set of second gen 5-spoke Z28 wheels and it was much easier to remove the trim rings if you let some air out of the tires....
Just a thought.
77thor is offline
post #6 of 6 (permalink) Old Apr 4th, 19, 08:39 AM Thread Starter
Apprentice
Chris
Just a thought.
Thanks for the replies,, I will give a it another try tonight.. While talking about rings, I whant to go to a 8 inch wheel with 4.5 BS. How many different depths of trim rings are there,, what should i be looking for.
The rims must have been swapped out sometime in the 90s to these 15x7s. i want to go back to 15x6-7 in the front and 15x8 in the rear.
chris
What to use to remove a pilot bushing, Bread! 68camaroz28 Tips & Tricks 8 Feb 14th, 19 04:04 PM
How to remove rear hard brake line Troutslayer Brakes, Suspension & Steering 24 Oct 23rd, 18 07:52 PM
1969 How to remove transmission lock? CDB Brakes, Suspension & Steering 7 Jul 15th, 18 12:03 PM
15x7 YH Wheels, Rings & Caps rsp6377 Wheels & Tires 14 Jan 7th, 18 09:08 PM
G.M. Trim Rings 3901708 redrocket1953 What's it worth? 0 Dec 28th, 17 08:17 AM
