1967 DB Rally Wheels - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 7th, 19, 04:41 PM Thread Starter
Probationer
Kenny
Smile 1967 DB Rally Wheels
Hello all. First post here. I have a set of DG rally wheels that I purchased to put on my Corvette but never actually got around to it. I believe that they are for a 1967 Camaro or Chevelle with disk brakes and are somewhat rare. They have some rust on them, but then again, they are 52 years old. They have center caps and the beauty rims as well. I'm sure I will never use them. Any suggestions?
Kenny
Axxeman is offline
post #2 of 7 (permalink) Old Apr 7th, 19, 04:52 PM
Ed
bertfam's Avatar
Re: 1967 DB Rally Wheels
What are the date codes on them?
Ed
Ed B. (but you can call me Bert!)
CRG -
bertfam is offline
post #3 of 7 (permalink) Old Apr 7th, 19, 06:15 PM Thread Starter
Probationer
Kenny
I'm not sure. How can I tell?
Axxeman is offline
post #4 of 7 (permalink) Old Apr 7th, 19, 06:45 PM
Ed
bertfam's Avatar
Post pictures of the numbers in front of, and behind the valve stems.
Ed
CRG -
bertfam is offline
post #5 of 7 (permalink) Old Apr 7th, 19, 08:58 PM
Garth
Regarding wheel codes...Camaro Chassis - Suspension, Axle, Brakes, & Wheels
Welcome aboard, Kenny ! If you don't have a use for them, I'm sure someone around here does have. Figure out what they're worth and post them in the classified section. https://www.camaros.net/forums/29-forum-classifieds/ Yes, pictures required...
Garfields Maro is online now
post #6 of 7 (permalink) Old Apr 8th, 19, 11:05 AM
Russ
From what I've read, in 67 the DG wheel code (along with others) was also used for 15 x 6 Corvette wheels, and also the 14 x 6 Camaro disc brake applications.
The date code will not be at the valve stem holes, only the DG. On the inside of the rim you might find a year and month stamp, such as a 67 and then a 2 nearby, and probably not aligned, for February 1967. It's also usually found near the other stampings. I've seen earlier ones without a date code present. So you'll want to verify the DG stamp and the size before listing them.
A few related old threads from the CRG site:
15x6 Rally Wheels with DG code on ebay
5 originals rallywheels 67 code DG
Name:	DG wheel.jpg
Petes L48 is offline
post #7 of 7 (permalink) Old Apr 8th, 19, 11:43 AM
Chick
68camaroz28's Avatar
There were 15x6 corvette dg wheels I believe but the more common wheel is DC. What is interesting is the 67 corvette 15x6 wheel utilizes the same trim ring as the 69z 15x7 wheel. Might want to check that out and sell separately.
Chick
68, 69, & 2015 Z/28's
69 Nova's L34 Father/Son & L78 Surv purch-new
67, 68, & 2015 Z06 Corvettes
Our 68Z Restoration
68camaroz28 is offline
15Ē Rally Wheels - Will they rub? Boucher421 Wheels & Tires 17 Oct 18th, 18 07:23 PM
What was the stock size rally wheels and tires 67 rs/ss camaro John D New Member Introductions 2 Sep 25th, 18 06:23 AM
14 x7 YJ Rally Wheels - Matched Set jdv69z What's it worth? 2 Dec 19th, 17 07:08 PM
