Small spare tire - Team Camaro Tech
 3Likes
  • 2 Post By SoCal805
  • 1 Post By HawkX66
post #1 of 5 (permalink) Old May 2nd, 19, 07:04 AM Thread Starter
Small spare tire
Guys - I'm looking for a space saver type of spare for my '68. Anyone know of any good outlets for a donut spare? I have 15" wheels with drum brakes in the back, disc in the front.
1968 Convertible
327 stock
Troutslayer is offline
post #2 of 5 (permalink) Old May 2nd, 19, 09:02 AM
Re: Small spare tire
you can buy "donut" size spare tires in 13,14,15", etc rim sizes. https://www.tirerack.com/tires/tires...190502155234:s
Typically a 4" wide rim but you need to find a rim that has enough back spacing to clear your rotor/drum with the right bolt pattern. The rim may be a hard find but could be made.
like any donut spare the diameter is likely shorter than your current tires (26"??) so using a donut spare that is smaller diameter is not advised on rear ends with limited slip or gear posi. In those cases if a rear tire needs swapping than pull one from the front and put the donut on the front. In any event these tires are only good for short low speed travel as turning and braking is affected with one tire being considerably smaller in diameter and width
FWIW my spare tire is AAA
Troutslayer and bhodgdon400 like this.
SoCal805 is offline
post #3 of 5 (permalink) Old May 2nd, 19, 09:23 AM
You could probably use the spare from an 80s or 90s Camaro. You'd have to verify height (25.6"-26.2"), but the bolt pattern is the same. 5x4.75. I'm sure it would fit over the calipers considering they have to for the cars they came off of.
Troutslayer likes this.
'69 SS396 X66 L34 08D (8/22/1969) M21 BS
460ci Gen VI 9.75:1
Semper Fi!
HawkX66 is offline
post #4 of 5 (permalink) Old May 2nd, 19, 11:29 AM Thread Starter
Thanks guys. Much appreciated.
1968 Convertible
327 stock
post #5 of 5 (permalink) Old May 2nd, 19, 05:25 PM
Be careful, limited slip equipped came with full size tires avoiding overheating of clutches.
Spare tire bucko Wheels & Tires 1 Sep 14th, 18 04:01 AM
69 front tire leans in bad 69crush Brakes, Suspension & Steering 5 Sep 9th, 18 02:36 PM
68 Spare tire Joe H Wheels & Tires 2 Jul 4th, 18 04:23 AM
69 spare tire mounting X-77 keith Wheels & Tires 0 Jul 1st, 18 02:27 PM
Beauty ring tire gap Jetlink Wheels & Tires 5 Jun 13th, 18 08:00 PM
