A slightly different front wheel question(s) - Team Camaro Tech
 1Likes
  • 1 Post By Larger Dave
post #1 of 10 (permalink) Old May 2nd, 19, 06:25 PM Thread Starter
I am nearing the point where I must have front wheels and tires. I have DSE control arms and Wilwood 6 piston brakes. Those ought to move my wheels out 3/8. Common wisdom says I need a 5-1/8 backspace.
Ok. I made a gadget to check my wheel clearances and I think 8” 235’s will about make it when against the stops turned out. I don’t even have a backyard alignment or 3 fat guys sitting on the crossmember yet to compensate for the lack of engine but so far so good.
The questions. Some tire makers like nitro only list max width not section and tread. Is there a rule of thumb for tread width deduct when all you know is the max?
Offset v backspace. One could think that an 8” wheel with a 4” backspace would have a zero offset, but it doesn’t. Backspace is measured from the inner lip. Zero offset is either half the distance between the rim edges or the tire seating surface depending on whose illustration you follow. I looked at some wheels in my pile and there is nothing standard on lip dimensions. So is the -12 offset conversion number typically listed for a 8” wheel with a 4” backspace kind of a wag or am I missing something?
3d cad is offline
post #2 of 10 (permalink) Old May 2nd, 19, 06:39 PM
Re: A slightly different front wheel question(s)
Maybe this will help:
https://rimsntires.com/specspro.jsp
I’m going to recommend against measuring for wheels with the suspension unloaded by the engine etc.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #3 of 10 (permalink) Old May 2nd, 19, 07:36 PM Thread Starter
Thanks Don. That’s a nice interactive chart. I was fooling around with it tonight trying to figure out how to setup the gadget I made. I hope to get the passenger side sheet metal on this weekend then I’ll winch it down and look at it a little more seriously.
3d cad is offline
post #4 of 10 (permalink) Old May 3rd, 19, 06:23 AM
I use this cheap tool to answer theses questions:
https://www.summitracing.com/parts/php-01201
Big Dave
Larger Dave is offline
post #5 of 10 (permalink) Old May 3rd, 19, 09:13 AM
DjD
DjD's Avatar
Check the back spacing to offset chart on the link below. A GM 15x7 rally wheel has 4.25" of back spacing (+6 offset) and centers the wheel and tire in a '69 wheel well. That's stock with disc brakes up front but works well as a general guideline when fitting wheels on a '69. Brake conversions do have some effect on this. Is that 3/8" you mentioned based on drum or disc brakes? It will make a difference. An 8" wheel at +6 offset is 4.75" backspacing, I can't imagine 5 1/8" backspacing working with an 8" wheel.
I have a 17x8 4.75" bs with 235/45 17 tires (c5 vette conversion disc's) and it's close on the inside during tight corners.
https://www.rsracing.com/TechWheel.aspx
...Dennis
DjD is offline
post #6 of 10 (permalink) Old May 3rd, 19, 11:47 AM Thread Starter
Hey Dave, i made a gadget to do that job kinda. I saw the beefs about getting the wire right so i made a tool for myself. Not quite prime time but it will do.
Dennis. Wilwood says that their setup moves my mounting surface out 3/8”. On a 8” wheel that gets me to 5-1/8. You’re not the first to doubt. MCB did too and offered to send me the tool Dave was referring to but .....
3d cad is offline
post #7 of 10 (permalink) Old May 3rd, 19, 01:52 PM
Try checking whatever tire you want on that manufacturers website. I found they have more "detailed" size 411
SoCal805 is offline
post #8 of 10 (permalink) Old May 4th, 19, 07:00 AM
DjD
DjD's Avatar
Use a straight edge against the wheel mounting surface and measure the distance to the closest inward point of contact to see how much space you have to work with. You'll have to take the section width (Nitto's overall width) of the tire into play to prove it out.
...Dennis
DjD is offline
post #9 of 10 (permalink) Old May 4th, 19, 07:40 AM
Additionally the aspect ratio is the side wall height vs the overall tire height. Usually they list the tire height and the overall width can be used to set up a simple algebraic equation (=) to solve for the unknown.
And my high school students used to ask all the time when will we ever need to use this stuff?
Big Dave
Daddio65 likes this.
post #10 of 10 (permalink) Old May 5th, 19, 12:28 PM Thread Starter
what I made to check the clearance. Gotta winch the car down a little yet. That setup adds 3/8 to the mounting surface dimension
ID:	226807   Click image for larger version
3d cad is offline
MOMO Steering Wheel Project Redux 57vette Interiors 8 Aug 15th, 19 06:30 PM
Front end wheel clearance differences on 68 Camaro's... Shan Wheels & Tires 3 Apr 27th, 19 05:47 PM
Yet another front wheel question 3d cad Wheels & Tires 2 Nov 18th, 18 06:10 PM
EDIT MOMO Steering Wheel Project 57vette Edit Forum 17 Dec 28th, 17 06:14 AM
MOMO Steering Wheel Project 57vette Interiors 15 Nov 27th, 17 05:18 PM
