Front Runners - Team Camaro Tech
post #1 of 2 (permalink) Old May 11th, 19, 03:59 AM Thread Starter
Jon
Front Runners
Hi all,
I'm placing a pair of 3.5" Centerline Auto Drags on the from of my 67 and I've noticed that the axel hub hole is very deep - 1.25 inch compared to 0.75 inch for the rear Centerline Auto Drags.
As a result the axel hole of the wheel overhangs the axel itself.
Is this unsafe? If so would I have to get a new hub assembly with deeper hubs?
Thanks in advance!
Heavychevy67 is offline
post #2 of 2 (permalink) Old May 11th, 19, 07:52 AM
Chuck
Re: Front Runners
A picture would be helpful but I'm thinking that what you need is a set of longer wheel studs: <https://www.jegs.com/i/JEGS/555/65100/10002/-1?mrkgcl=1239&mrkgadid=3332957860&adpos=1o1&creati ve=330726016715&device=c&matchtype=&network=g&jegs promo=nonbrand&gclid=CjwKCAjw5dnmBRACEiwAmMYGOQT4N 8IplzaIaoj5RBkxorFlpA_nNXBaYSyfE907Rt5FUvt7cRg52ho Cv0QQAvD_BwE>
In order to be acceptable during an NHRA tech inspection the stud should engage the hex portion of the nut by at least the diameter dimension of the stud.
cnorton7311 is offline
DIY help with replacing front springs/shocks to lower a '68 68Cam350 Brakes, Suspension & Steering 7 Jun 26th, 06 03:12 AM
Rebuilt Front Suspension - Now Front End Is STILL Too High Rack Man Brakes, Suspension & Steering 7 Apr 3rd, 06 05:19 AM
Hood adjustments!! Handy69Z Body Shop 2 Mar 13th, 03 04:14 AM
Rear of hood does not line up SSuperman Body Shop 9 Apr 1st, 02 05:00 PM
Hanging Doors ? wesley58_do Body Shop 6 Jan 30th, 02 11:23 AM
