Tough nut to crack - Team Camaro Tech
 2Likes
post #1 of 20 (permalink) Old May 14th, 19, 09:51 PM Thread Starter
Pat
Tough nut to crack
I donít know who put these lug nuts on or what they used but... I got 4 loosened after a lot of work, but #5 is not budging. I put a cross lug wrench on and stood on it and bounced to get some of them moving.
So far Iíve broken a socket extension, a socket adapter, and a socket. Nuthin. Tried the cross lug wrench, an 18Ē breaker bar, an impact driver, several BFHs, and the dreaded pipe extension on the ratchet. Nuthin.
#5 is starting to round off, so I'm worried I may have to resort to cutting.
Heading to the store tomorrow to pick up an electric impact wrench and a 3/4Ē half-inch drive socket.
Pat - 68 Camaro Coupe -
patman2 is offline
post #2 of 20 (permalink) Old May 15th, 19, 12:08 AM
Re: Tough nut to crack
Big time, air powered, impact wrench, six sided socket.
130fe likes this.
Mike - '68 Camaro - aftermarket or modern pretty much everything.
Mkelcy is offline
post #3 of 20 (permalink) Old May 15th, 19, 02:33 AM
Vega$69's Avatar
Use a nut splitter and it wonít damage the wheel stud.
https://www.amazon.com/2pc-Nut-Split...a-720570140601
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 20 (permalink) Old May 15th, 19, 08:03 AM
Vince
Put 2 back on either side of the tough one and tighten them then work on it. I have used the handle from a HI LIFT JACK as the breaker bar.
1967 327 4spd convertible 119K
1968 RS Z/28 04D Norwood have owned twice
1968 RS Z/28 04D Van Nuys asleep for 36 years
1969 Z/28 X33
3forme is offline
post #5 of 20 (permalink) Old May 15th, 19, 09:15 AM
Lesson learned here - when tightening/loosening, only do 1/4-3/8 turn per nut in a star pattern.
Works eveytime
Doing a good job is like peeing in your dark pants Ö you get a warm feeling, but nobody notices
Everett#2390 is online now
post #6 of 20 (permalink) Old May 15th, 19, 11:54 AM
Vega$69's Avatar
If the threads are galled itís gonna break the wheel stud
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #7 of 20 (permalink) Old May 15th, 19, 03:32 PM
Garth
From the description, I'd say the threads are most likely fubar already. Probably installed haphazardly with an impact gun. Might as well plan on replacing both (stud & nut) and just break it off with a breaker bar/pipe.
Garfields Maro is offline
post #8 of 20 (permalink) Old May 15th, 19, 04:22 PM
Put the nuts back on and go to a tire shop....they have a tool to remove locking nuts. May work ?
(and shop air should be 125ish too )
What kind of wheels ?
Are you re-using/selling/or ?
Last resort split it length wise as far as you can and then a chisel....extreme caution !!!!
68 Camaro~LSx ~all motor
post #9 of 20 (permalink) Old May 15th, 19, 08:03 PM
keith
X-77 keith's Avatar
As mentioned a 6 point socket is a must. I have used heat and a candle. The wax from the candle will wick up in the threads and help break it free. Sounds dumb, but been doing it for years on tough bolts. No particular scent candle.
ctcz28 likes this.
X-77 keith
X-77 keith is online now
post #10 of 20 (permalink) Old May 16th, 19, 10:59 AM Thread Starter
Pat
The wheel needs to come off so I can do the last corner of my brake rebuild. 3 down, one to go.
Theyíre all 15x8 corvette rally rims, with BFG 235-65ís. They have a lot of tread on Ďem, actually look almost new...BUT, they have a mfg date of 1993, so theyíre going in the bin.
I may try the heat and candle wax method, Iíve heard of that one before. Iím just running out of patience. I have a nut cracker but I'm not sure I can get it in there to do the job. The car isnít road-legal right now, so driving it anywhere is out.
Naturally my air compressor died this winter, so now Iím going back and forth between replacing that and getting an electric impact wrench.
patman2 is offline
post #11 of 20 (permalink) Old May 16th, 19, 11:48 AM
Jon
Break it off. Replace it when the wheel is off.
Jon N
dyno jonn is offline
post #12 of 20 (permalink) Old May 16th, 19, 01:55 PM
Garth
Yep, he needs more leverage ! I assume all the tools broke in the original post were 3/8" drive ? I'll loan ya my 3/4" drive set up if you pay the shipping.
post #13 of 20 (permalink) Old May 16th, 19, 03:40 PM
Vega$69's Avatar
If you donít want to split it or cut with and dremel and break the nut off the stud you need an impact wrench. The more leverage technique is going to end up hurting for sure.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #14 of 20 (permalink) Old May 16th, 19, 05:17 PM
bob
Need a 1/2" drive 24" breaker bar and add a piece of pipe to it. Or go 3/4" drive......
bob15 is offline
post #15 of 20 (permalink) Old May 16th, 19, 06:45 PM
Heat nut with torch.
Mostly Camaros and FINALLY a Double Nickel
Yellow69RSZ is offline
Time for another 68 Z/28 to be restored 68camaroz28 Build Projects 1410 Jan 13th, 20 08:42 PM
Steering shaft nut? Marc Brakes, Suspension & Steering 4 Mar 23rd, 12 07:36 AM
67 seat belt holder nut Big Iron Interiors 12 Jan 12th, 12 04:17 AM
Rag joint nut and bolt, where can I get? gordr Brakes, Suspension & Steering 5 Dec 28th, 11 09:37 AM
Broken Speed Nut MCGOO Brakes, Suspension & Steering 10 Aug 20th, 07 09:49 PM
