centerline auto drag size - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 28th, 19, 08:23 AM Thread Starter
Probationer
Who out there is running Centerline auto drags on the front of their 69 Camaro? I have come across a set that measure 15x8.5 rear and 15x7 front with 3.25+/- back spacing. My car has stock suspension components and need info on what tire size I should consider to keep from rubbing on the fenders. Pictures with wheel/tire specs would greatly be appreciated. Thanks in advance
stj69 is offline
post #2 of 2 (permalink) Old Jun 28th, 19, 08:59 AM
Re: centerline auto drag size
You need more like 4.5" back spacing. Those are more like the set up for Corvettes I think and will rub on the front at least. I run Ansen style slotted mags on my 69, but I rub The inside top lip of my fender on some bumps. Eventually I'd like to find a set with better back spacing. There are a lot of threads with wheel and tire sizing info if you do a search. You don't even need to do a search. Just look at the sticky for 69. Gives you the answer right there. https://www.camaros.net/forums/17-wh...re-combos.html
'69 SS396 X66 L34 08D (8/22/1969) M21 BS
460ci Gen VI 9.75:1
Semper Fi!
HawkX66 is offline
