Tire spacers - Team Camaro Tech
 1Likes
  • 1 Post By dhutton
post #1 of 8 (permalink) Old Jul 14th, 19, 09:57 AM Thread Starter
Probationer
Too steele
Angry Tire spacers
I have just put new a arms on my 68 camaro. I have coil overs on it. My 18 inch 245/40ZR Tires are now half an inch from the wheel well. They hit each other when rolling over lightly inclined patch in the road. I noticed I have spacers that look like an inch thick. My question is... are there thinner spacers I can put on that would put the tire further in the wheel well so it wonít hit when rolling over jumps in the road? If so, what size?
Lmetoyer is offline
post #2 of 8 (permalink) Old Jul 14th, 19, 11:34 AM
Andrew
Andrew69's Avatar
Re: Tire spacers
You got a photo of this spacer? You could maybe take them by a machine shop to have them lathe cut to the thinner dimension. Depending on what the spacer looks like.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 8 (permalink) Old Jul 14th, 19, 11:43 AM
Ed
bertfam's Avatar
Re: Tire spacers
Just take the spacers off!
Ed
Ed B. (but you can call me Bert!)
CRG -
bertfam is offline
post #4 of 8 (permalink) Old Jul 14th, 19, 12:33 PM
Brett
Re: Tire spacers
You mentioned Coil-overs. You didn't by chance install 2" drop spindles did you? I sure hope not.....
Brett.....
1969 SS 396 X66 - RS Conversion - TKO600 - 3.73 Posi - Paint Code 71-LeMans Blue
Brettallen59 is offline
post #5 of 8 (permalink) Old Jul 14th, 19, 01:42 PM
Re: Tire spacers
Did you get a front end alignment after you did all that work? You need one and it will affect tire rub. David Pozziís site lists recommended alignment specs.
FIRST GEN SUSPENSION
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #6 of 8 (permalink) Old Jul 14th, 19, 02:51 PM
Rufas
Re: Tire spacers
Wheel spacer and adapter vendors and manufacturers advertise all over the net, and on EBay as well. I just had to get a pair for an old boat trailer I am converting to pull with my 64 Chevy 1 ton flatbed dually to use for repairs all over the area I live in.
There are spacers that simply slip over longer wheel studs, ones that have two different bolt patterns (one bolts tothe wheel pattern, the other to the new wheel pattern, to change from one circle to another), 4 to 5 lug, and back, all sorts.
dave ray is offline
post #7 of 8 (permalink) Old Jul 14th, 19, 07:14 PM
Chris
Re: Tire spacers
As stated, many thicknesses are available. Check out Jegs or Summit for some ideas.
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #8 of 8 (permalink) Old Jul 14th, 19, 07:55 PM
Re: Tire spacers
If all that was done is a control arm swap there should be no need for wheel spacers. Fix the front end alignment. See it all the time, guys donít get an alignment after doing front end changes. Bad practice....
allanjs likes this.
dhutton is offline
