US Mags Rambler on '69 Camaro - Team Camaro Tech
 1Likes
post #1 of 16 (permalink) Old Aug 28th, 19, 09:03 PM Thread Starter
Anyone put these US Mags Ramblers on their '69? If so, what size and backspace did you use and do they fit without rubbing.
https://www.summitracing.com/parts/u...6152/overview/
I'm thinking about getting some 18x8 for front and 18x9.5 for rear. Hoping I could fit maybe a 245 on front and 275 on the rear. Mine is lowered by about 2" though.
Anyone have pics they can share with these on their '69? I currently have 17" and hoping the 18" won't look too big.
dcaver is offline
post #2 of 16 (permalink) Old Dec 3rd, 19, 03:54 PM
Joe
Re: US Mags Rambler on '69 Camaro
I was looking at these as well. They only come with 4 1/2 inch backspace on a 18x8 chevy wheel. I need 4.75 to not rub the outside of the tire up front. It's too bad; they are a nice looking wheel.
Joe G
69 Coupe; ZZ430; TKO600; 3.55 posi; 13" Baer 4 wheel discs; 17" Billet Specialties wheels; Hotchkis/Koni rear; Ride Tech front; Classic AutoAir AC and power windows cuz I'm old and lazy!
Joe G is offline
post #3 of 16 (permalink) Old Dec 3rd, 19, 05:46 PM
Vega$69's Avatar
I put a set on a 66 Chevelle. Really liked them and really good price
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 16 (permalink) Old Dec 3rd, 19, 07:30 PM Thread Starter
I heard they fit '69 with no issue. What is making you need 4.75 backspace? What size tire are you looking at going with. I still haven't pulled the trigger on any wheel just yet.
RaiderNation67 likes this.
dcaver is offline
post #5 of 16 (permalink) Old Dec 4th, 19, 12:48 AM
Louis
If I get the wheels 18x8 and bs is 4.5Ē what is the best size tire and whatís a good offset so the tires donít rub
Sent from my iPhone using Tapatalk
RaiderNation67 is offline
post #6 of 16 (permalink) Old Dec 4th, 19, 05:59 AM
4.5 backspacing on an 8 inch wheel is 0 mm offset.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #7 of 16 (permalink) Old Dec 4th, 19, 07:12 AM
Vega$69's Avatar
245/40R18
With the 4.5" backspace possible rub. May be able to run a couple degrees neg camber to reduce rubbing.
Another possibility could be to machine 1/4" off the wheel to increase BS. I would not do this without consulting the manufacturer first.
Vega$69 is offline
post #8 of 16 (permalink) Old Dec 4th, 19, 03:54 PM
I just bought these and was trying to get them to fit my '67 but they won't fit on my Baer Track 4 brakes (posted just after you did). Now I have to return them. I got 245 and 275 tires for the 8" and 9.5" wheels - Firestone Firehawk Performance tires.
AZ_Bill is offline
post #9 of 16 (permalink) Old Dec 5th, 19, 12:37 PM
Chuck
Send a message via AIM to ChuckD Send a message via MSN to ChuckD
I too am interested in these wheels for my 69. The "Tires/Wheels" section does not give me enough clarity. I will go with 235's in front and 255's in back, same 18" wheels, 8" front, 9.5" rear. Hesitating, as I'm not sure they will fit. I may just buy one of each wheel and see how they fit while estimating the tire OD and section width as described on the BFG website. I'd hate to buy and mount only to have a problem of non-returnable tires and wheels.
Let us all know what you end up with.
69 Z-28-Glacier Blue, X-77
ChuckD is offline
post #10 of 16 (permalink) Old Dec 13th, 19, 06:33 PM
Joe
My 69 is lowered. I have 24 inches from grade to bottom of fender lip. I run a 235/50x17 Bridgstone Pole position tires on Billet Specialties Ventec wheels. They have 4 1/2 backspace. These tires are a wide 235. The tires rub just a bit at the top of the fender lip on turning. I also am running negative .5 degree camber to reduce rubbing.
Another 1/4 of backspace would clear with these tires.
Joe
Joe G
Joe G is offline
post #11 of 16 (permalink) Old Dec 14th, 19, 01:54 PM
Steven
stamatisg1977's Avatar
I have ridler wheels. Same as the us mags
Im running
215/45/18 on an 18x8 wheel up front
275/35/18 on a 18x9.5 in the rear
I have a speedtech front sub with the coilovers at the lowest setting and a 4-link in the back at the lowest setting and i have no issues
Car is still in build stage lol
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #12 of 16 (permalink) Old Dec 15th, 19, 09:09 AM
Im running
These are what I went with as well to clear my Baer Track 4 brakes. Works great!
AZ_Bill is offline
post #13 of 16 (permalink) Old Dec 15th, 19, 10:04 AM
Tim
I have the exact ones you are looking at and although my car is not running I don't appear to have any rubbing or clearance issues. You can see a couple of pictures in my build thread. I really like the two tone and they were a great price from Summit - arrived in two days.
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #14 of 16 (permalink) Old Dec 15th, 19, 04:34 PM
Joe
They look great!
Joe G
Joe G is offline
post #15 of 16 (permalink) Old Dec 17th, 19, 09:32 AM
Probationer
Bob
Here's a pic I have them on my car. They are 18x8 rims. Front tires are 225/r45 and rear tires are 255/r45.
69_IDOL is offline
