What TTIIs for non-lowered 68? - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 16th, 05, 09:19 AM Thread Starter
What 17" TTIIs for non-lowered 68?
Sorry about the same old same what size tire/rim question. However, I wanted to make sure I have the right setup.
I have a 383 with a front disc conversion kit and all new stock suspension. I want to run 17" TTIIs.
Should I run 17x8s with 4" back spacing on the front and 17x8s with 5" backspacing on the back. With 235/45/17's on the front and 255/45/17's on the back.
Is this the optimal setup for no scrubbing with no fenderlip modification?
I am really at a loss. Thanks for your input, this site is great!!
jhilts is offline
post #2 of 5 (permalink) Old Sep 16th, 05, 09:33 AM
67 Camaros Rock
Joe Harrison's Avatar
Re: What TTIIs for non-lowered 68?
Not sure but I think you will need 4 1/2 on the front. I believe the rear should be fine. I am looking at the same thing right now but i am going to use TTO wheels but same sizes.
Joe
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #3 of 5 (permalink) Old Sep 16th, 05, 09:55 AM Thread Starter
Thanks Joe - Please let me know what you find out.
jhilts is offline
post #4 of 5 (permalink) Old Sep 16th, 05, 10:45 AM
thought 4 3/4 was the correct b/s for 17's all the way around???
1967 4 speed convertible, 350/295
timbo68 is offline
post #5 of 5 (permalink) Old Sep 16th, 05, 11:44 AM
Richard
Rich67's Avatar
On my 67, I have 17X8 with 4 3/4 bs 255/45 on the rear. Lowered 1 inch. No rubbing at all. There looks like there is plenty of room for another 1/4 inch bs too. That rear combo should be fine especially if you are not going to lower.
My front setup is 16X8 with 4 3/4 bs 245/45/16, lowered 2 inches. It barely clears the fender lip and the frame at full turn. Overall diameter of the tire is 24.6. Your tire will be 25.3. With only 4 inches of bs it might still clear the frame at full turn. I'm not sure about the fender lip though, but if you are not going to lower it you might be ok.
Rich
Rich67 is offline
front vibration dampeners for 68 conv rick 68 conv Convertibles 3 Sep 15th, 05 08:17 PM
