how can i tell if my rims are 14x7 or 14x6? - Team Camaro Tech
post #1 of 7 (permalink) Old Sep 21st, 05, 11:16 AM Thread Starter
I have some old beaten up cragar ss's on my 67 bird right now. They are new 14 inch tires, so I just want to get new rims.
How do I know whether they're 14x6 or 14x7??
i dont have the car at this location so i dont' know what size tires are on it.
m21man is offline
post #2 of 7 (permalink) Old Sep 21st, 05, 12:04 PM
Vintage 68's Avatar
Thumbs down Re: how can i tell if my rims are 14x7 or 14x6?
I don't have a tape measure in my pocket...
And even if I did - your question can't be answered...
If you posted the tire size, then we could recommend a rim width range.
You will need the tire size, if you plan to keep them, before you purchase the rim size(s) recommended for that tire.
The rim width of the present rim was probably taken into account when they were mounted - it would be a good starting point.
How can you tell rim width? measure from rim-bead to rim-bead on the inside of the rim...
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 7 (permalink) Old Sep 21st, 05, 02:44 PM Thread Starter
i will have the diameters tonight, for you guys, and I'll try to measure from bead to bead as well. see what i get.
m21man is offline
post #4 of 7 (permalink) Old Sep 21st, 05, 06:02 PM Thread Starter
the tires are 215/60/14.
does that sound like a 14x7 rim?
m21man is offline
post #5 of 7 (permalink) Old Sep 22nd, 05, 08:02 AM
Vintage 68's Avatar
A 215/60X14 would nominally require a rim width from 6.0" ~ 7.5".
So a 7.0" rim is right near the middle of the range and would be perfect
The rim width is important to give the correct 'Section Width' to the tire and allow the tread to contact the road correctly.
Hope this helps;
1968 Convertible
Some trucks
post #6 of 7 (permalink) Old Sep 22nd, 05, 04:59 PM
Smile Re: how can i tell if my rims are 14x7 or 14x6?
Put a straight short 1x across each side on the sidewalls so you can measure down to the lips on both sides and subtract both numbers from the distance the boards are apart at the center hole.
And if you measure 7" you have 6" rim and 8" you have 7" rim.
This is b/c generally a rim is about 1/2" wider per side then the measurement between the "beads" with the tire off for strength purposes.
pdq67
post #7 of 7 (permalink) Old Sep 25th, 05, 05:01 PM
take the car or one wheel to a tire shop they have a guage that can tell you exactlly what width rim it is and doubt if they would charge you to do it!!!! I wouldnt go by tire size cause i have seen way to wide of tires on wheels that were way to narrow
camarofreak is offline
Aftermarket rims and front end vibration faninc Brakes, Suspension & Steering 5 Aug 9th, 05 07:10 AM
Chassis shake at 45MPH-with new Rally Rims faninc Wheels & Tires 4 Jul 14th, 05 02:40 PM
Keep 15x8 Rally rims or American Racing Steel rims DenRS Bench Racing 3 Jul 9th, 05 07:30 AM
14x6 Rally rims and disc brakes Gulcher Wheels & Tires 6 Oct 21st, 01 06:18 PM
69 Camaro Rims and Tires Balboni Wheels & Tires 3 Oct 24th, 00 09:40 AM
