I got hosed off EBay. What would you do? - Team Camaro Tech
post #1 of 12 (permalink) Old Sep 27th, 05, 09:47 AM Thread Starter
I bought some rally wheels off a private seller on Ebay last year. My car is finally getting to point that I will need them (Finally). I didn't realize how important back spacing was when I bought them.
All 4 are 15x7s, but the backspacing is different on one. Three have 3 and 3/4" back spacing and 1 has 4 and 1/4" back spacing.
Do I buy another one with 4 and 1/4" back spacing or do I buy another with 3 and 3/4" back spacing. Which do you think will look better? Will it look odd if the backspacing is different between the front and back?
I had bought some brand new tires 215/65/15 for the front and 245/60/15 for the back.
jhilts is offline
post #2 of 12 (permalink) Old Sep 28th, 05, 06:59 AM
Re: I got hosed off EBay. What would you do?
I actually had the same thing happen a couple years ago buying wheels for my 55 Chevy. It actually worked out to be the best. The one deeper BS wheel actually ended up looking and fitting better on the front of my car than the other three. I ended up buying one more wheel to match the deeper BS and everything worked out for the best.
Good luck
Buildinga55 is offline
post #3 of 12 (permalink) Old Sep 28th, 05, 07:33 AM
DjD
DjD's Avatar
Test fit the wheels and then decide...
...Dennis
DjD is offline
post #4 of 12 (permalink) Old Sep 28th, 05, 08:41 AM
Wes
The 4.25 inch backspacing was used on our first gens. I'm sure you could fit larger tires using this.
If you buy used, take them to your local tire store,.. and have them spun. I'd bet that a third to half of all Rally's sold on e-bay are bent and unusable (I've purchased about a dozen for different projects).
Also, in the Year One catalogue you can still purchase brand new Kelsey Hayes Rally's with the offset mentioned above, 15x7 for about $90 ea.
Good luck
Straight-line-69 is offline
post #5 of 12 (permalink) Old Sep 28th, 05, 11:45 AM Thread Starter
Thanks guys.
I called Rick's and they suggested putting the 4.25 on the front, just like you guys suggested.
I found out three of them are AG code which only came on the 68 Corvette, they had a special offset that year.
I think I may just sell it all and start over new. I think I would probably feel more comfortable with new wheels.
jhilts is offline
post #6 of 12 (permalink) Old Sep 28th, 05, 12:54 PM
Wes
If you have a choice, and want new wheels (good call) order the Kelsey Hayes, which is the original manufacturer of the Chevy Rally wheel. They still make them in the popular sizes and Year One is the only vendor I know of that sells them.
Others sell repos and they're not hub centric, and are only "fair" copies of the original wheels.
My opinion!
post #7 of 12 (permalink) Old Sep 28th, 05, 02:23 PM
Ryan
You could always put a spacer on the one with the 4-1/4" backspacing to make it match the others. I know others have used spacers to make newer original wheels from corvettes and so on fit on early camaros. I am not sure how they work but I would think you would have to put longer wheel studs in with the 1/2" spacer. Maybe others will have some input.
fishin4info is offline
post #8 of 12 (permalink) Old Sep 28th, 05, 06:37 PM
Spacers are old school and dangerous, not enuff stud on stock set up.. measure , then make decision and go buy new ones... I got 4 that wobble.
TC # 349
zdld17 is offline
post #9 of 12 (permalink) Old Sep 30th, 05, 07:07 PM
Stay away from wheel Vintiques brand aftermarket rallys- just sent 7 wheels back...they were all out of round and shook the car badly.
good luck
JL
faninc is offline
post #10 of 12 (permalink) Old Sep 30th, 05, 07:15 PM
67 Camaros Rock
Joe Harrison's Avatar
That one from the vett is rare find. To the best of my knowledge they only had that backspace one year and it was 68. If it's strait find one more and use them on the front, with a 225, 60 15 and put an 8 inch rally trim ring on it. Buy two 15x8's and put 255 60 15's in the rear and 8 inch rally trim rings. It will look like you have 15x8's all around the Camaro because of the trim rings. This set up looks very good and no rubbing on the 68 I had it on or my 67.
How much will you sell it for shipped to zip 71701?
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #11 of 12 (permalink) Old Oct 1st, 05, 01:19 PM Thread Starter
Someone from Washington emailed me about the wheels also. I am not even sure what they are worth.
I have decided to sell them though.
jhilts is offline
post #12 of 12 (permalink) Old Oct 1st, 05, 02:19 PM
I have 15x8 OE Rallyes that had a 4" back spacing. The local wheel repair guy cut and re-welded them for less than au$50 each. He also repaired a badly buckled 15x7 for au$35.
My point is it may not cost much to correct them exactly where you want or need them.
Also, the spacer plates are not bad because of the stud length/nut engagement. Even with long studs, they're a bad idea.
It's because the spacers do not support the stud between the axle flange and the wheel. There is generally are large multi fit hole for various stud diameters and bolt circles with a spacer thickness of 1/2" or more for the studs to flex. That's bad.
IF you insisted on using spacers, do not use multi-fit styles. At least use a spacer that snugly fits the studs with 7/16" holes, and make sure you have no less than 1.5 times the stud diameter of thread engagement. (7/16" x 1.5 = 11/16")
Or better still, get the correct backspace.
BlackoutSteve is offline
eBay Safeharbor Department Email Is this a scam? Pro Street Garry Bench Racing 11 Apr 27th, 05 04:58 PM
new ebay scam mwh Bench Racing 3 Feb 10th, 05 02:14 AM
Ebay Account - credit card scam ??? csn69ss Bench Racing 16 Feb 6th, 05 06:43 PM
Is this a new ebay scam? check it out chevyboy68 Bench Racing 5 Aug 25th, 04 02:35 PM
Is this a new ebay scam? check it out chevyboy68 Bench Racing 2 Aug 23rd, 04 04:50 AM
