Lug Nuts for 69 w/ TTII's? - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 28th, 05, 08:09 PM Thread Starter
Rodney
I just got a set of 17" Torque Thrust II's (used), and need to know what kind of lug nuts to use? I have heard that you use acorn style lug nuts, which is what I have from my Rally's, but I just want to make sure. Don't want to be driving down the road and have one of my new(to me) 17x8/17x9.5's, pass me up.
Also, what is the torque specs for these rims?
Thanks for the help
69 RS Camaro (383,700r-4,12-bolt w/4.11s)
79 WS6 Trans Am (406SBC,factory 4-spd,3.23 posi)
87 GTA Pace Car Clone (350TPI,700r4)
97 Bonneville SSE 40th Anniv. (3800 V-6,All Power)
Check out my site at
wildkatz is offline
post #2 of 8 (permalink) Old Sep 28th, 05, 10:28 PM
Re: Lug Nuts for 69 w/ TTII's?
yes, use acorn style, BUT a word of caution. I found that my stock axle (12 bolt) studs were too short for the TTIIs. Check your thread engagement. I think I went with 1/2'' longer studs. (from Advance Auto)
yellowrallys is offline
post #3 of 8 (permalink) Old Sep 29th, 05, 02:12 AM
Mr. Tibbs
Send a message via AIM to ChevyThunder
I just put the same rims on my 69..I asked about the tq and was told about 75lbs...I will have to look at the lug nuts..
" Burn rubber not your Soul "
Camaro,Camaro,Camaro,Camaro
ChevyThunder is offline
post #4 of 8 (permalink) Old Sep 29th, 05, 06:31 AM Thread Starter
Rodney
Thanks for the reply's.
How much of the stud should stick thru? Or how much of the lug nut should thread on?
ChevyThunder, car looks great, what color is that? Black or dark burgundy?
Thanks again.
wildkatz is offline
post #5 of 8 (permalink) Old Sep 29th, 05, 06:57 AM
Jody
camcojb's Avatar
You will have to change the stock rear studs. You'll be lucky to have 2-3 threads of engagement if you don't. VERY dangerous.
Jody
camcojb is offline
post #6 of 8 (permalink) Old Sep 29th, 05, 05:12 PM Thread Starter
Rodney
Ok, checked the threads. The front lugnuts thread on 10 times to seat in, the rear thread on 5 times. So this isn't enough?
wildkatz is offline
post #7 of 8 (permalink) Old Oct 7th, 05, 02:40 PM
I'd like to know the answer to this also. I put them on my car and didn't really notice if they were short or not. I have the car put away for the winter and only put about 10 miles on the TTII's before I put the car away. If I need to change the studs I'd like to know before the cold weather really hits me. Thanks in advance.
Dave, 69 Coupe, 383, Q-jet, Thorley headers, 350 turbo, P.S., P.B. console gauges, Tilt wheel, Black with green pearl paint, Black and White Houndstooth interior.
Black69 is offline
post #8 of 8 (permalink) Old Oct 7th, 05, 04:54 PM Thread Starter
Rodney
I just tightened them down(6 turns) and have drove it about 150 miles. They haven't loosened up any and haven't had any problems so far. I am actually looking for a set of lug nuts that go back in the rim and use a washer, but so far have only found ones that are too large and won't thread into the hole.
wildkatz is offline
Rims Other Than TTII's??? Who's Got What??? jay'srs/ss Wheels & Tires 3 Sep 17th, 05 03:09 PM
Kool nuts or ARP's? Zman Performance 4 Jul 11th, 05 07:12 PM
Radiator Mounting - How do the well nuts work? ggkeller Body Shop 3 Apr 3rd, 05 05:32 PM
2 Nuts for $50 on ebay, are they nuts? click Bench Racing 26 Jan 5th, 05 06:28 AM
Lug nuts for Torque thrust II Conehead396 Wheels & Tires 0 Oct 26th, 04 02:03 PM
