Recommended tire/rim size - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 9th, 05, 05:52 AM Thread Starter
Chris
ckaram's Avatar
My wife has green-lighted an upgrade of my tires and wheels (woo hoo!).
I want to go 16" x 8" wheels. Chevy High Performance lists out the largest possible tire/wheel measurements, but I don't want to stuff them in my wells and risk rubbing. So, here's my questions:
1. What is the recommended tire size for these rims (not the largest possible with slight rubbing)?
2. Should all 4 tires be the same size? This would lengthen tire life but what benefits are there for bigger rear tires besides the look? Any handling benefits?
3. What backspacing should I have? Running drum brakes all around now but will upgrade the fronts to disc someday.
I'm thinking about Boyd's Sting Ray wheels. Here's a link:
http://www.newstalgiawheel.com/produ...ls.asp?id=1720
Thanks all.
Check my rides:
1968 Camaro Convertible LS1, T56
2016 Challenger RT Scat Pack Shaker
ckaram is offline
post #2 of 3 (permalink) Old Oct 9th, 05, 06:58 AM
Re: Recommended tire/rim size
An 8" rim will hold a tire from 235 to 265, plus or minus a size.
The biggest advantage to larger tires in back is that much larger tires will fit there, and look better, ie: fill the wheelwells better. 225 is about tops in front, while 255 is an easy fit in back.
I run a 225 on a 7" rim with 4" BS in front, and a 255 on an 8" with 4 1/2" BS is back
Thanks all.
Note: the sizes I'm listing are "comfy" and absolutely not the biggest that can be stuffed in there!
post #3 of 3 (permalink) Old Oct 10th, 05, 06:53 PM Thread Starter
Chris
ckaram's Avatar
Thanks JimM. This is harder than I thought...
Check my rides:
ckaram is offline
What size head gasket do I need with this bore? Burnsamatic Performance 8 Jul 12th, 05 12:55 PM
Head gasket bore size and impact on ring sealing Tokyo Torquer Performance 14 Jan 24th, 05 05:08 AM
Front tire/rim size on 67 w/ 12'' discs zless67 Wheels & Tires 14 Mar 9th, 03 11:13 AM
who knows how to size the head of a bolt when its measured in thread size cottonpicker14 Tech 2003 7 Jan 22nd, 03 11:10 AM
Tire/rim size on '69 Camaro awsm69 Wheels & Tires 4 Feb 7th, 02 10:56 AM
