Better backspacing for 17s 4.75" or 5"? - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 12th, 05, 11:02 AM Thread Starter
Question for the guys that are running 17" wheels. I plan to run 17x8 wheels on all 4 corners. Do you recommend 4.75" or 5" backspacing all the way around?
My suspension is new but stock. I have a front disc conversion kit on the front. I plan to run 235/45/17 on the front and 255/45/17 on the back. Of course I am open to running a 245/45/17 on the front if I won't experience any rubbing.
I have searched through the forums and have heard of people running both 4.75" and 5" backspacing, I just wanted to get some feedback on what works.
Thanks!!
jhilts is offline
post #2 of 6 (permalink) Old Oct 12th, 05, 11:30 AM
Re: Better backspacing for 17s 4.75" or 5"?
When I ran 17's, I used 4.75" of BS with a 245/45. It only rubbed the frame at full lock. It wasn't extreme by any means, but it did rub slightly. If I were to do it again, I'd run the same setup.
69ProTouring is offline
post #3 of 6 (permalink) Old Oct 12th, 05, 12:14 PM Thread Starter
Do you think running 245/45/17 with the 5" b/s would solve the rubbing issue or am I thinking about it backwards?
jhilts is offline
post #4 of 6 (permalink) Old Oct 12th, 05, 12:52 PM
Rod
I have a 69 Camaro w/ a SBC and I am running 235/45/17s on a 17x8 with 4 7/8" BS on front and 275/40/17s on a 17x9.5 with 5.5" BS. I have all new Hotchkis/GW suspension components which lower the front 2" and the rear 1.5". I have no rubbing at all while driving, but the passenger side front wheel will hit the frame rail at full lock when turning right (while parked). 245/45/17s would fit on the front of my car no problem.
If there isn't a huge price difference I would go with the larger 5" BS as you could always add a spacer if needed.
Rod
69 Camaro with LS2/4l70e
Rocketrod is offline
post #5 of 6 (permalink) Old Oct 12th, 05, 01:02 PM Thread Starter
Sounds Great!! You know I wanted to go with the 17x9.5 like yours but I had read on some of these forums that you needed to roll the fender lip. If that is NOT true I would rather run those. Since my suspension is stock, shouldn't I have more room to play with on the rear?
jhilts is offline
post #6 of 6 (permalink) Old Oct 12th, 05, 02:37 PM
Rod
My fender lips were rolled by the previous owner, sorry forgot to mention that since I bought it that way.
With stock suspension and the low profile 17s the distance between top of tire and wheelwell will be excessive and won't look right w/o some lowering IMHO
Rod
14x6 rally wheels with diff. backspacing? faninc Wheels & Tires 0 Oct 10th, 05 06:12 PM
Front wheel backspacing Justin'n Mel Performance 2 Apr 1st, 04 11:41 AM
Cragar Mag Reverse Backspacing Question redlines4us Wheels & Tires 3 Aug 13th, 02 05:32 PM
4.5 backspacing? awsm69 Wheels & Tires 3 Feb 21st, 02 03:13 PM
Backspacing required for 10" wheel? Jeff H Wheels & Tires 2 Nov 16th, 01 02:06 PM
