15x7 FW rally wheels backspacing - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 21st, 05, 10:18 AM Thread Starter
Chuck
Quick question about rallies.
Do all 15x7 FW rally wheels have the same backspacing?
Thanks,
Chuck
chuckm is offline
post #2 of 7 (permalink) Old Oct 21st, 05, 10:34 AM
Vintage 68's Avatar
Re: 15x7 FW rally wheels backspacing
Quick answer = No...
You'll need the rim code and manufacturer to know for sure.
Many are close to 4.25~4.5" though...
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 7 (permalink) Old Oct 21st, 05, 10:41 AM Thread Starter
Chuck
Code is K15 20FW. Does that help?
chuckm is offline
post #4 of 7 (permalink) Old Oct 21st, 05, 12:41 PM
Vintage 68's Avatar
It does - but, you may want to recheck numbers - there seems to be a digit (or so) missing from one side or the other of the valve stem.
The "FW" is a 'JJ' rim profile 15X7" rim with a .30"* offset.
GM #3997899 (Group 5.803) with applications from 1969 ~ 1975.
Listed as a service replacement for part #3970531 wheel for 1969 Camaros w/Disc Brakes Front and Rear (RPO-JL8) and w/ 302 option (RPO-Z28).
Listed as a standard or replacement wheel for 1970~75 Monte Carlo and 1974~75 Chevelle (exc. wagon).
Welded construction, 4 cap projections and Tubeless rated.
Code you gave may be missing a number or two - but, looks like a Kelsey Hayes Rally from the Romulus, MI plant manufactured in ? (1975?) on ???
*Some conflict in GM documents about this - measure the 'backspace' and see if it isn't slightly more than 4 1/2".
Hope some of this helps;
1968 Convertible
Some trucks
post #5 of 7 (permalink) Old Oct 21st, 05, 01:53 PM
Wes
Yes, they will all have 4.25 inch backspacing. "FW" is a 15 x 7 rally wheel used on Monte Carlos in the early 70's,..and will work great on your first gen.
Straight-line-69 is offline
post #6 of 7 (permalink) Old Nov 3rd, 05, 08:31 PM
eric
Im New Here But I Can Say I Have 15x7 4.25 Bs 215/65 And They Look And Fit Awsome!
RUSTY69 is offline
post #7 of 7 (permalink) Old Nov 4th, 05, 06:24 PM
Thumbs up Re: 15x7 FW rally wheels backspacing
I bought 6 FW all sandblasted and painted for $45.00 each. Saves a lot of extra money ,instead of buying certain coded wheels,and not knowing if they are bent or not.
Put them on a 68 SS matching 4 speed with drum brake all around.
Flynn69 is offline
GM Rally Wheels "XC" code-what Car? faninc Wheels & Tires 9 Oct 13th, 05 09:22 AM
14x6 rally wheels with diff. backspacing? faninc Wheels & Tires 0 Oct 10th, 05 06:12 PM
15" rally wheels japper Wheels & Tires 7 Aug 30th, 02 09:18 AM
15x7 rally wheels mr69 Wheels & Tires 2 Feb 28th, 01 04:02 PM
