What size torque thruster II's on a 69 - Team Camaro Tech
post #1 of 13 (permalink) Old Oct 28th, 05, 06:31 AM Thread Starter
Billy Moss
I want to put the american torque thruster II's on my 69 Z. Can anyone give me feedback on what will fit based on actual experience. Will probally go with 16" or 17 " and wide as possible on rear without rubbing. Any help would be appreciated. Thanks
cortezsilver is offline
post #2 of 13 (permalink) Old Oct 28th, 05, 09:15 AM
Re: What size torque thruster II's on a 69
Here's mine with 17's on it. 17 x 8 ont he front and 17 x 9.5 on the rear. I have 255's on the rear and you can see there is plenty of room for a 275.
Dave, 69 Coupe, 383, Q-jet, Thorley headers, 350 turbo, P.S., P.B. console gauges, Tilt wheel, Black with green pearl paint, Black and White Houndstooth interior.
Black69 is offline
post #3 of 13 (permalink) Old Oct 28th, 05, 10:09 AM Thread Starter
Billy Moss
Looks great. What was the backspacing on front and rear and what width tire?
post #4 of 13 (permalink) Old Oct 30th, 05, 08:29 PM
The front has 4.75 inches of backspacing and the tire is a 225 45 17, the rear has 5.5 inches of backspacing and the tire is a 255 45 17.
Black69 is offline
post #5 of 13 (permalink) Old Oct 30th, 05, 09:55 PM
Mr. Tibbs
Send a message via AIM to ChevyThunder
I a useing the exact same 17" TT II's with the same back spacing as Black69 and I have 245's up front and 275's in the rear and they work perfect
" Burn rubber not your Soul "
Camaro,Camaro,Camaro,Camaro
ChevyThunder is offline
post #6 of 13 (permalink) Old Nov 2nd, 05, 07:21 AM
Here is mine with 16's. They are 16x8 with 4.5bs and 245/50 in rear and 16x7 with 4.5 bs and 225/50 in front.
slck6t9 is offline
post #7 of 13 (permalink) Old Nov 2nd, 05, 07:30 AM
slck6t9 is offline
post #8 of 13 (permalink) Old Nov 2nd, 05, 09:26 AM
Trev
madcarson's Avatar
I have 17x11 on rear with 325-40-17 skins no clearance issues
madcarson is offline
post #9 of 13 (permalink) Old Nov 4th, 05, 10:45 PM
Trev
madcarson's Avatar
[QUOTE=madcarson]I have 17x11 on rear with 315-35-17 skins no clearance issues so far
post #10 of 13 (permalink) Old Nov 6th, 05, 01:20 PM
Looks nice on your car.
What brand is it on those tires, what can you recommend?
BowtieSweden is offline
post #11 of 13 (permalink) Old Nov 6th, 05, 07:05 PM
I am a big fan of the Nitto 555's they are a very sticky street radial. I have a friend who has they and he has very good luck
(well as much as can be expected with out a slick) hooking his 600hp stang on the street. Please don't confuse the 555 radials with the 555r drag radials. I will be purchaising a set with my TTII's...
69 Camaro RS, 383ci,10.5-1 AFR 195's ported, Comp 286HR, 4340 forged Crank & Rods, JE Pistons, RPM Airgap, Holley 750 HP carb, 350 turbo w/ shift kit, 3000 Coan, Be cool, caltracs,12bolt 355 eaton posi..Best E.T. 12.22 @ 112
69CamaroRacer is offline
post #12 of 13 (permalink) Old Nov 7th, 05, 12:47 PM
Looks great on both ChevyThunder and Black 69:s cars with 17".
You are both using 17"x 8 in the front with 4.75 backspace, but if you want same size on the rims Rear, what backspace fits best then?
Anyone know that?
post #13 of 13 (permalink) Old Nov 17th, 05, 11:24 PM
Send a message via AIM to Omaha SS
I'm in the process of restification on my '69 SS right now. I have the Detroit Speed mini tub kit for the rear. I'm considering going with 17x8 front and 17x11 rear. Is this going to work and what backspacing would I need? Also, what tire sizes would you recommend? I'd like the tire sidewall heighth to be even on both wheels front to back.
-'69 Camaro SS 396 X66 (project car)
-'12 Subaru WRX hatchback (daily driver/AutoX/track day)
-'98 Dodge Ram 2500 (Camaro parts hauler)
Omaha SS is offline
69 Yenko Specifications.. figures needed CUL8R Troubleshooting 2 Oct 10th, 05 04:21 PM
Whats the key to throttle response? 67CamaroD Performance 44 Apr 23rd, 05 08:08 AM
Torque converter size CamaroMan79 Performance 6 Jun 10th, 01 02:42 PM
torque vs horsepower b-boy Engine 9 Jan 15th, 01 03:33 PM
