Correct backspace for Torq-Thrust II - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 7th, 05, 08:20 AM Thread Starter
Question How much backspace will work 69 Camaro
I have a 1969 Camaro riding on monoleafs with 10 bolt rear/ssb front & rear disc brakes. My Torq -Thrusts are 15 X 8 with 3 3/4 bs. Rear tires are BF Goodrich P255/60 R15. I am using air shocks to stay off the inside lip of my wheel wells. I want to eliminate the air shocks(Big mistake installing them). How much back space can I handle with the above setup to stay off the inside of wheel wells? Looks like I need to move the rear tires in about 1/2 to 3/4 inch. Will 15 X 8 with 4 1/2" back space fit around brakes & shocks????
ritchiefarms is offline
post #2 of 4 (permalink) Old Nov 17th, 05, 03:58 PM
Re: Correct backspace for Torq-Thrust II
I have a 69 with monoleafs. The 10 bolt is from a Nova. The rear brakes are Wilwood. Not the exact same setup as yours. I am using American Racing Torque Thrust II's, 15x8 with 4.75 backspacing. 275/60/15 tires. No problem with the inner or outer fender. The inside of the wheel is VERY close to the caliper. I would need a micrometer to measure the clearance between the caliper and the wheel weights on the inside of the wheel.
Bill Miller is offline
post #3 of 4 (permalink) Old Nov 18th, 05, 08:58 AM Thread Starter
Smile Re: Correct backspace for Torq-Thrust II
Thanks Bill. I have ordered TT II's with 4 1/2" bs to be safe. American Racing says there should be no problem. We will soon see. What monoleaf are you using??? I plan on replacing mine with CalTracs 2 piece mono's and use their taction bar set up. Any experience with this set up. CalTrac people say this should give about another inch of cleareance so I can get rid of the air shocks.
post #4 of 4 (permalink) Old Nov 22nd, 05, 11:35 AM Thread Starter
4 1/2 back spacing centers the 255/60 R15 perfect. No rub and no air in the shocks. I now have 2 Torque Thrust II 15x8 with 3 3/4 back space for to sell if anyone needs two. Great condition.
Okay, scratch the correct carb needed post. TClovis Tag Team 0 Aug 10th, 05 12:56 PM
Correct A.I.R. Smog Tubes? Littletommy Engine 2 Apr 16th, 05 05:06 AM
numbers correct 327/275 bluesdog Restoration Corner 0 Feb 1st, 05 03:46 PM
sizes from Chevy High Performance article michaelm5 Wheels & Tires 10 Jan 16th, 03 02:53 PM
finally new wheels and tires michaelm5 Wheels & Tires 14 Jul 12th, 02 01:09 PM
