need Wheel help.. with narrowed rear end - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 12th, 05, 07:00 AM Thread Starter
Send a message via Yahoo to shooterpcb
I have a 67 Camaro with a narrowed Dana 60 that is 48 inches wide hub-hub. I want to use a 15x10 wheel and was wondering if any of you had this same setup and what did you use for tire and what wheels with what backspacing do you have? My car's rear is tubbed. Thanks!!!
"There are two ways to do this... My way and the Wrong way." - Dale Earnhardt '99
Neil
shooterpcb is offline
post #2 of 3 (permalink) Old Nov 18th, 05, 03:58 PM
Re: need Wheel help.. with narrowed rear end
I also have a 67 SS with a narrowed Dana 60 and tubbed. I used 15x10 weld pro star with a 3.5 back spacing, and 325/50R15 BFG drag Radials and installed a 3.5 inch billet spacer, this aligned the front and rear tires nicely and gives the car a nice stance. if you're interested in the spacers let me know and I'll try and find the manufacturer for ya.
Rat67SS is offline
post #3 of 3 (permalink) Old Nov 19th, 05, 08:04 AM
Use a straight edge at wheel mounting area and measure in to tub (closest point) and then measure out from inner to wheelwell lip (closest point). This will give you a close idea to max BS and max width, then you'll need to allow for tire flex and growth.
Make a cardboard cutout and see how it fits in all positions (don't forget suspension travel). That should give you an idea of tire size and wheel size. Good luck !
68 Camaro~LSx ~all motor
rear end conversion chevellon Brakes, Suspension & Steering 5 Oct 31st, 05 07:53 AM
For the CRG Guys; Rear End Stuff Supertrunk Tag Team 1 Sep 26th, 05 12:43 PM
Need new rear end for 69 criddell Transmission & Driveline 5 Aug 3rd, 05 06:40 PM
Decode 12 Bolt Rear End 68and69ss Tag Team 1 Jul 30th, 05 11:06 AM
Stock width of 67 Camaro Rear end 67Kevin Wheels & Tires 4 Apr 19th, 05 08:12 AM
