15in wheel question - Team Camaro Tech
post #1 of 3 (permalink) Old Nov 15th, 05, 09:30 AM Thread Starter
Jason
15in wheel question
Ok...I'm looking to go with 15 in wheels (just want to be different than the 17+ crowd) and have seen some state that 235/60 will fit all the way around. Question is what fits when you've installed the Hotchkis drop kit front and rear?
Any help appreciated.
JD
1968 Camaro Coupe 327 worked over
Omnipotent is offline
post #2 of 3 (permalink) Old Nov 15th, 05, 11:28 AM
Re: 15in wheel question
i have the hotchkis springs all round
just to compair sizes i have 245/50R16 in the front, they rub alittle, just because they are so tall
next time they will be 245/45R16, so try and find a hight that is close to that and 245 should work fine
400bird is offline
post #3 of 3 (permalink) Old Nov 16th, 05, 12:09 PM
Chris
I also have the Hotchkis 2" drop front & rear springs/sway bar. I am running 235/60/14 BFG's on 14x7 rally rims on all corners and do not have any tire rubbing issues. Header clearance is another story....
Your wheel offet will play the biggest factor.
1969 Camaro
Electric Blue Lacquer Paint
355/400 HP, M-21 4-Speed, 8.5 10-Bolt 4:11 Posi
Cal69 is offline
