1969 Z/28 Tires - Team Camaro Tech
post #1 of 8 (permalink) Old Nov 21st, 05, 11:01 AM Thread Starter
Smile 1969 Z/28 Tires
I have a 1969 Z/28 R/S Camaro. Can somebody give me some suggestions on what tire size to buy for this car. What size are most people out there using for a car like this? I would like to stay close to the factory size for the car, unless they will look too small. The wheels are 15” x 7” factory rallys obviously. Thanks.
Doug
dh302 is offline
post #2 of 8 (permalink) Old Nov 21st, 05, 11:34 AM
Chuck
chuck69ss's Avatar
Re: 1969 Z/28 Tires
Original tires would have been some type of poly/glass E70-15. Firestone still makes Wide Oval and SC200 that look original. For better performance, you could go with radial equivelent, but I'm not sure what that would be.
Chuck B
RI
- Frost Grn, x11, 350 4bbl, COMPCam XE256H, Crane XR-i HEI, M20, posi, Flowmaster 2.5";
You can live in your car, but you can't drive your house.
chuck69ss is offline
post #3 of 8 (permalink) Old Nov 21st, 05, 02:13 PM
Hans
Re: 1969 Z/28 Tires
The approximate modern tire size equivalent to an E70-15 is a 205-70R15.
Regarding radial or bias-ply, I think that's a presonal preference and will depend on how you intend to use the car.
'69 RS Z28 Cortez Silver, Original Driveline, M22, 73K, Van Nuys Built, Chassis Broadcast Copy
'69 Chevelle SS396 4SP, Fathom Green, Original Engine
'06 GTO Brazen Orange, M6, 400HP LS2
sandiegoz28 is offline
post #4 of 8 (permalink) Old Nov 21st, 05, 05:16 PM
JohnZ's Avatar
Re: 1969 Z/28 Tires
Mine had 235/60-15 T/A radials on it when I bought it, and I had some front fender rubbing with it (all original springs); replaced them with 215/65-15 radial T/A's early last summer, no more rubbing.
JohnZ
CRG
JohnZ is offline
post #5 of 8 (permalink) Old Nov 21st, 05, 06:31 PM
Norm
LT1FUN's Avatar
Re: 1969 Z/28 Tires
Would the 225/60/15 BFG T/A's fit OK with the factory 15 X 7 rallys? Can someone tell me what backspace the factory rallys are?
69 Camaro SS X55
70 Camaro RS/Z28
LT1FUN is offline
post #6 of 8 (permalink) Old Nov 22nd, 05, 10:14 AM
William
William's Avatar
Re: 1969 Z/28 Tires
An additional concern on an RS are the actuator brackets/shields, particularly the LF. When I was parting these things out 20 years ago it was common to see a hole worn through the LH shield.
I ran 205/65s on my RS Z/28 and had a slight rub on occassion.
William is offline
post #7 of 8 (permalink) Old Nov 22nd, 05, 10:31 AM
Re: 1969 Z/28 Tires
I am running 225R60 on front and back of my 69Z. These are mounted on 15x7 rims. I will be changing the back to 245R60 on 15x8 soon.
SCHOON is offline
post #8 of 8 (permalink) Old Nov 22nd, 05, 08:37 PM Thread Starter
Smile Re: 1969 Z/28 Tires
Thanks everybody.
Doug
dh302 is offline
