Ordering Rims Today!!!!!!!!! Questions????? - Team Camaro Tech
post #1 of 13 (permalink) Old Nov 28th, 05, 02:00 PM Thread Starter
Jason
jay'srs/ss's Avatar
Question Ordering Rims Today!!!!!!!!! Questions?????
So i ended up choosing the Intro Twisted Vistas w/ a polished finish. 17x7 Front & 17x8 Rear. I'm gonna be running Baer Brakes all the way around, 13" rotors front & 12" rotors rear. Lowered 2" front & 1.5" in the rear. And Speedtech Tubular A Arms top & bottom.
So i guess i'll be running 245/45/17's front & 275/45/17's rear. With a 4.75" Backspacing front & a 5.5" Backspacing in the rear.
Does that sound about right? I wanna make sure the tires won't rub and i'll have enough clearance for the brakes.
These are the rims.
My Cars:
70 Lemans Sport 350 w/ 48k Original Miles!!! SOLD!!!
SOLD!!!
88 Camaro IROC-Z SOLD!!!
SOLD!!!
jay'srs/ss is offline
post #2 of 13 (permalink) Old Nov 28th, 05, 03:43 PM
Christropher
Re: Ordering Rims Today!!!!!!!!! Questions?????
Order a set for me too
Christropher
...in pieces still.
clwilcox33 is offline
post #3 of 13 (permalink) Old Nov 28th, 05, 03:51 PM
Armando
tejasrs/ss's Avatar
I'm gonna keep a close eye on this thread cuz I have the same car with the same drop and the same brakes. How much were those wheels?? thye are sweet! .. let me know how it comes out!!
Armando
1967 Chevy Camaro RS/SS
2012 Ford F150 Supercrew FX4
2007 Ford Mustang GT/CS (sold)
2002 F150 Harley Davidson (sold)
tejasrs/ss is offline
post #4 of 13 (permalink) Old Nov 28th, 05, 04:34 PM Thread Starter
Jason
jay'srs/ss's Avatar
Should come out to around $1,700 for the wheels. I'm probably going with Yokohama AVS Sport tires. My brother worked at America's Tire Co for 3 years, he said those are good tires. So i figure $2,500 for the wheels and tires total.
My Cars:
SOLD!!!
SOLD!!!
post #5 of 13 (permalink) Old Nov 28th, 05, 05:47 PM
Andrew
Andrew69's Avatar
I believe that with those rim widths your front should have about 4" backspace, and the rear should have about 4.5" backspace.
The '69 Z cars had 7" width with 4" backspace. That seems to be the center point to work off of.
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #6 of 13 (permalink) Old Nov 28th, 05, 08:08 PM Thread Starter
Jason
jay'srs/ss's Avatar
That's what i was thinking also. But, in accualty the rims are overall an inch wider than advertized. So the 7" are really 8" from bead to bead. Kinda odd i know. So the backspacing i mentioned above should be okay. I might go less an .25" just to be safe.
My Cars:
SOLD!!!
SOLD!!!
post #7 of 13 (permalink) Old Nov 28th, 05, 08:47 PM
Armando
tejasrs/ss's Avatar
did I read somewhere that the baer brake kit changes your backspacing a lil bit??
Armando
post #8 of 13 (permalink) Old Nov 29th, 05, 09:41 AM Thread Starter
Jason
jay'srs/ss's Avatar
Don't know? Guess i'm gonna have to find out.
My Cars:
SOLD!!!
SOLD!!!
post #9 of 13 (permalink) Old Nov 29th, 05, 10:14 AM
Garry
Those are nice wheels. A buddy of mine has a set on his '65 impala.. Except his are 20's and 18's.
1969 LM1 Convertible Camaro
The restoration is ON!!
Musclecar is offline
post #10 of 13 (permalink) Old Nov 29th, 05, 11:33 AM
baer brake add less than 1/4" of B/S if you originaly had drums
and almost nothing if you had factory discs
thats just what i have heard here, i didnt measure them myself
400bird is offline
post #11 of 13 (permalink) Old Nov 29th, 05, 06:10 PM
Andrew
Andrew69's Avatar
I belive your offsets are pretty close if your front wheels are 8" and your rear are ~ 9.5"
Skunk Works
Some photos:
Member # 159
post #12 of 13 (permalink) Old Nov 29th, 05, 06:25 PM
ya they are what i have heard for 8" front and 9.5" rear
but they may not be right for 7" front and 8" rear
thats there wierdest thing i have ever heard, that the 7" wide rim is actualy an 8" wide rim,
unless you are refering to the outside of the rim being 8" wide, and the inside edge of the beads is 7", then that is normal, and you might want to change your backspacing, or order wider rims
400bird is offline
post #13 of 13 (permalink) Old Nov 29th, 05, 07:17 PM
I agree with 400bird on checking the backspacing again. I just put 17x8 w/ 4.75bs on front with 245/45/17 and 17x9.5 w/ 5.5bs and 275/40/17 on rear. With 7 and 8 inch rims I think your backspacing is off and if you use the same tire size I did, I think it would look a little off with 7 and 8 inch rims.
slck6t9 is offline
