rear tires and rims - Team Camaro Tech
post #1 of 9 (permalink) Old Dec 4th, 05, 04:17 PM Thread Starter
rear tires and rims
I want to buy weld wheel pro stars for my 68 camaro, I was hoping someone could tell me what the fattest tire I could put on the rear, without problems might be, plus I need to know what back spacing to use for the tires to work properly.
iisonsg is offline
post #2 of 9 (permalink) Old Dec 4th, 05, 08:44 PM
Harley D
HarleyD67's Avatar
Re: rear tires and rims
I'm in the same boat. Ordering new wheels over winter. There are several posts on this in the last few months just do a search. Is your car lowered or stock. What size wheel 15",17" ect? I know you said Prostar so I assume 15". I have a max size list from Weld for several cars and wheel sizes that they put out a couple years ago. I've test fit a couple wheels on my car 15"x8" with 4.5"bs and 275/60 R15 is snug but it fits stock ride height. Your safest bet is 255/60 R15 Fits very well no issues. Not tight, even with slightly lowered cars. Again assuming stock brakes rear end ect.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #3 of 9 (permalink) Old Dec 5th, 05, 05:11 AM Thread Starter
Yes it is getting a 15" rim, it sits at stock highth. Thank you for your help I will e-mail weld and see if I can get me a max size list also.
iisonsg is offline
post #4 of 9 (permalink) Old Dec 5th, 05, 01:35 PM
15x8's or 8.5's with 4.5" bs, 275/60/15 tire.
I have 285/60/15 SH with slight rub issue, but I deal with it.
click to enlarge
68 Camaro~LSx ~all motor
post #5 of 9 (permalink) Old Dec 5th, 05, 05:57 PM
I've got 15x8 with 4.5 B/s 275-60-15 pics in my sig
georgia 69 is offline
post #6 of 9 (permalink) Old Dec 5th, 05, 07:03 PM Thread Starter
Thanks for the replies and the pics.
iisonsg is offline
post #7 of 9 (permalink) Old Dec 18th, 05, 08:29 PM
im running 275/50/15 bfgradial t/as on the rear with 15 8.5 auto drags with4.7/8backspacing hadto bend up outer wheel well lip a little bit but does not rub even with2inch drop in rear . the look from behind is hot. ps not a hack job and tires do not stick out of wheel wells , very rodger penske trans am look, good luck
dougs68ss is offline
post #8 of 9 (permalink) Old Dec 18th, 05, 08:37 PM
doug your a sick dude, my daughter does the same thing happy hollidays!,,,,doug
post #9 of 9 (permalink) Old Dec 18th, 05, 09:04 PM
Farm Boy's Avatar
I tried 15 X 8 wheels with 5” backspace with 255/60-15 tires on my ’67. It looked like they had enough clearance sitting in the driveway but the sidewalls rubbed the inner wheel wells when cornering or entering driveways at an angle. I then installed 15 X 8 wheels with 4.5” backspace and the same tires don’t rub even with a full tank of gas and passengers in the back seat.
Farm Boy is offline
