A little rubbing on front TTII - Team Camaro Tech
post #1 of 11 (permalink) Old Dec 28th, 05, 11:08 AM Thread Starter
Just thought I'd run this by you guys. I've finally got the car on the road this fall and my front wheel setup seems to be a little too big. Every so often I hit a dip in the road and the front drivers side tire hits the fender lip. This is what I've got:
front 245/45/17 17x8 bs 4.75
rear 265/40/17 17x9.5 bs 5.5
2" drop in front 1.5" in rear
Is this common for that big a wheel?
I was thinking of downsizing to a 17x7 bs 4.75 to bring the wheels inbord by 1 inch.
Any thoughts?
http://community.webshots.com/photo/...00966276MMawvq
BEN-67 is offline
post #2 of 11 (permalink) Old Dec 28th, 05, 11:29 AM
Re: A little rubbing on front TTII
a 245 is big. They will scrape the lip, and the rear of the frame when you turn to full lock. Addiitonal backspace may help, but you may not have a full inch. turn the wheel to full lock and measure clearance between the sidewall and the subframe.
What about alignment specs? 1 degree neg camber will buy you some space, and the guldstrand mod will buy you more because the camber will go more negative when the suspension compresses (with stock geometry the camber goes positive!)
I ran a 245 tire long ago, it was hard into the sub when turning, and I had to scalop the top of the inner fender and roll the lip to get the outside of the tire to clear. I run 225's now.
post #3 of 11 (permalink) Old Dec 28th, 05, 11:39 AM
Carl
Where does it rub and what are your alignment settings?
CarlC is offline
post #4 of 11 (permalink) Old Dec 31st, 05, 11:54 AM Thread Starter
I do have the Guldstrand mod on the car. As for alignement specs, I don't know them exactly but the camber must be around 1 deg neg. The rubbing is on the inside of the fender lip straight in the middle, driver's side. I've mesured the "ground to fender lip" height and it seems to be 3/8" higher on the passengers side. At full lock the wheels rub the frame just a bit.
245 might have been too ambitious. Running 225 seems more resonable. I think I can borrow a set from a friend. I'll try'em out in the spring, we're knee deep in snow now. The Falken tires I have on stick like glue, I've never felt the car was loosing traction while turning. I hope 225 will have enough grip.
BEN-67 is offline
post #5 of 11 (permalink) Old Dec 31st, 05, 12:04 PM
Robert
I'm running 235's on the front of the '69 with the same drop and wheels as you. No rubs up front so far. I had to add a 1/4 spacer in the rear with 255/45/17. Seems like when you max out the wheel/tire combo every car has a little different issue to deal with.
Robert
TC member #18
rojo is online now
post #6 of 11 (permalink) Old Dec 31st, 05, 01:19 PM
Rod
Are the front spring new or did you cut/torch an old set to get the 2" drop. If the latter that may be the problem.
As JimM said you may be able ta get a little clearance with an alignment. Maybe Mr. Pozzi can give you some alingment specs. When running 245/45/17 you need more backspacing ideally 4 7/8" to 5". I have 235/45/17 on 17x8s with 4 7/8" BS and have plenty of room for 245s.
Rod
69 Camaro with LS2/4l70e
Rocketrod is offline
post #7 of 11 (permalink) Old Jan 1st, 06, 09:12 AM
You might just need a little more backspacing. I run the same setup with 245's and don't come close to rubbing anywhere. I run 5" of backspacing, though. I was originally going to get 4.5" bs, but went with 5" bs for the added margin of clearance and it turned out to be the prudent thing to do. I was even considering 275's with extra backspacing up front. I think I would be ok on the frame, but the stock control arms look to be a problem.
cudaman is offline
post #8 of 11 (permalink) Old Jan 5th, 06, 07:58 AM
Ben,
Are you having any trouble with rubbing in the back? Have you had passengers in the back? I'm thinking about the same rear setup in my 67. Did you do the Global West springs to get the 1 1/2" lowering?
I wonder if going to a 235 tire in the front would help your rubbing issues? I would also like to go with 17 X 8 in the front but 5" of backspacing seems like a lot form the measuring I've done. Let me know what you decided to do.
stevecolo is offline
post #9 of 11 (permalink) Old Jan 5th, 06, 01:48 PM
I just realized that you have a '67. The info I gave you was for a 69, which can handle a slightly fatter wheel and appears to tuck the wheels slightly inboard of the 67-68. You could use a tad more backspacing to solve that, but then you would probably be rubbing on the inside. You might have to settle for 235's in front.
cudaman is offline
post #10 of 11 (permalink) Old Jan 10th, 06, 10:34 AM Thread Starter
The suspension is all new Hotchkis. I did have four people in the car at once but I was driving below 35MPH. Didn't have any rubbing in the rear. I find that the rear wheels don't fill out the wheel well enough. There is to much clearance around the wheel. I'll eventually go for a 45 or 50 profile. Live and learn.
BEN-67 is offline
post #11 of 11 (permalink) Old Jan 11th, 06, 11:38 AM
i have the same tires and wheels as you i ordered 17-8 5 bs and they sent me 4.75 they rubbed so i sent them back and got 5bs no problems since. guys on here told me to order 4.75 then a member emailed me and said ill have problems with 4.75 and i took his word and ordered 5 he was right when i cheacked with the wrong wheel that came in.
jigga99 is offline
