69 conv wheels 18" and 20" - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 11th, 06, 12:30 PM Thread Starter
Cool 69 conv wheels 18" and 20"
Hi !!!
Any body that have tried too run there 69 on 20" back and 18" up front ??
If i would like too hear about what backspacing that will fit with out too cut and weld the wheelhousing..
Thanks...
pace is offline
post #2 of 3 (permalink) Old Jan 11th, 06, 06:08 PM
Re: 69 conv wheels 18" and 20"
In the front 235/40-18s on 18x8 with 4.75 backspace.
In the rear 255/35-20s on 20x8.5s with 5.25 backspace.
The rear will work with no problem at all even on a very low car (top of the wheel at the lip of the fender. In the front if the car is very low and you want tire sidewalls to be equal front and rear you can drop down to a 225 tire.
There are plenty of cars here with wider tires in the front and wider wheels and tires in the rear. When it comes to the really big wheels in the rear the car has to sit pretty low for them to look good (althought some people feel they will never look good LOL) You may be able to squeeze a 275/35-20 on a 9.5 wheel with 5.5 to 5.75 backspace in the rear but if the car is low it will be very tight and will probably rub on curb cuts. The sizes that I gave you at the beginning of the post I have seen work on a 69 so I know they are good.
JV69z/28rs is offline
post #3 of 3 (permalink) Old Jan 12th, 06, 10:35 AM Thread Starter
I will go for the 225/40-18 front and the 255/35-20 rear as you mentions, that will look great.
Thanks from overseas..
Kim 69 conv
pace is offline
