285/40/17 on rear of 68? - Team Camaro Tech
post #1 of 10 (permalink) Old Jan 11th, 06, 04:46 PM Thread Starter
has any body used this size on their car yet? im switching to 17's and want to go as far as ican in size. the 275/50/15's on ther now are only 3/8 " narrower.... going to use Z06 wheels. thanks
dougs68ss is offline
post #2 of 10 (permalink) Old Jan 11th, 06, 05:04 PM
Re: 285/40/17 on rear of 68?
there was a thread earlier this week of almost the same question, i recomend a search
and if the tires are olny 3/8" wider, why dont you just see if you have 3/8" of room to spare, and double check and compair the back spacing?
and sorry i dont really have an answer, but for most cars 275 is the widest
400bird is offline
post #3 of 10 (permalink) Old Jan 11th, 06, 05:23 PM
Robert
I don't have an answer either but it sounds like time for a fender lip roll to me. If the car is lowered I doubt it.
Robert
TC member #18
rojo is offline
post #4 of 10 (permalink) Old Jan 12th, 06, 04:52 PM
Here's an article on a 68 Firebird with those size rear tires on 17x9 rims with 6.5" backspacing. He's running a road race suspension set-up, so body lean is minimal. Not a Camaro, but PDC.
http://highperformancepontiac.com/fe...4hpp_firebird/
Sporter is offline
post #5 of 10 (permalink) Old Jan 12th, 06, 07:43 PM
Smile Re: 285/40/17 on rear of 68?
I think that I could have fit a 295/45-17 on about 17" x 9", w/ 5.5 b/s on my car?
The bottom of the shock which gave my old L-60's, (a measured 298/53-14), on 14" x 9", w/3.5" b/s Fenton Slotted Mag rims fits would fit inside the 17's for more clearance.
I had to raise my car about 4" to 4.5" using coli-overs to fit them, but I still had almost 1.5" inside at the bulge if not for the shock bottoms hitting.
pdq67
post #6 of 10 (permalink) Old Jan 13th, 06, 01:11 PM
I have 285/60/15's on my 68 with slight rub on hard turns and off camber (like turning into a driveway). Stock wheel wells and lip not rolled.
I would cut a cardboard template and check fit first.
68 Camaro~LSx ~all motor
post #7 of 10 (permalink) Old Jan 13th, 06, 03:59 PM
Question Re: 285/40/17 on rear of 68?
Doug G,
You didn't mention rim widths and back spacing?
And if you had to raise it some either?
Please come back with more info.
Thanks,
pdq67
post #8 of 10 (permalink) Old Jan 14th, 06, 04:16 AM
Mono springs (original)
15x8 weld prostars,4.5" bs
stock height (plus old springs might be lower/worn)
ie: tight fit.
edit : I forgot to mention they're 285 SH (shorts) 27.4T x 11.7W so they claim.
post #9 of 10 (permalink) Old Jan 14th, 06, 08:05 AM
Kent
15x8 weld pro stars, 4.5 back space. Cooper Cobra tires 295/50 series. fender lip rolled
wardee is offline
post #10 of 10 (permalink) Old Jan 14th, 06, 04:23 PM
Thumbs down Re: 285/40/17 on rear of 68?
Sorry, but I feel that an 8" rim is TOO narrow for a true 295 section tire!!
My L-60's at 298 bulge quite a bit on my 9" rims!
pdq67
