what size is better 15x8 or 15x10 - Team Camaro Tech
post #1 of 6 (permalink) Old Jan 15th, 06, 07:34 PM Thread Starter
scott67ss396's Avatar
Question what size is better 15x8 or 15x10
looking to put some old school cragars on my 72 camaro I have a new M/T 275x50x15 drag radial what rim should i use the 10 or 8 need your help guys
the front will be 15x6 using M/T sportsmans 26x7.5x15
1967 SS (496) BBC FiTech EFI
1972 454 Fitech EFI (Baldwin motion clone)
1978 Trans am Gold SE W72 (461)
scott67ss396 is offline
post #2 of 6 (permalink) Old Jan 15th, 06, 08:11 PM
Re: what size is better 15x8 or 15x10
10s will be tight, and the BS needs to be perfect
but i think the tire will work better, and it will not bubble out as much
but wider is better
400bird is offline
post #3 of 6 (permalink) Old Jan 15th, 06, 08:55 PM
Keith
The rule of thumb is that the rim width should be from 1 inch wider to 1 inch narrower than the tread of the tire you intend to run. A 275 has a 8.8-9 inch tread so either will work fine. A 15x8 will fit your car better as far as keeping the tire under the car.
69X11 is offline
post #4 of 6 (permalink) Old Jan 16th, 06, 10:33 AM Thread Starter
Talking Re: what size is better 15x8 or 15x10
well i just took a tap measure to see what I had on before. looks like I had 15x10 with 4.5 B/S I measured from lip to to lip and its 10 across almost got the 8s. glad I was bord today
post #5 of 6 (permalink) Old Jan 16th, 06, 11:07 AM Thread Starter
or did I measure them wrong?
should it say the size on the wheel they are weld pro stars
post #6 of 6 (permalink) Old Jan 16th, 06, 03:28 PM
Smile Re: what size is better 15x8 or 15x10
Out to out is generally 1" wider than where the two tire beads fit.
My old-school 14" Fenton slotted mags measure 10" and are 9" wheels.
pdq67
