225/60 15 tire on 68...will they rub? - Team Camaro Tech
post #1 of 17 (permalink) Old Jan 20th, 06, 08:59 AM Thread Starter
I know everyone is probably tired of these questions, but I am buying new tires for 15x7 rallys. I want to buy 225/60 15s all around, but will they rub in the front? Most posts that I've seen on these indicate no problems, but I have read a few that said there may be rubbing. Any thoughts?
newjob1975 is offline
post #2 of 17 (permalink) Old Jan 20th, 06, 09:00 AM Thread Starter
Re: 225/60 15 tire on 68...will they rub?
The car is a 68 convertible. 2" lowered springs in front, stock spindles.
post #3 of 17 (permalink) Old Jan 20th, 06, 09:14 AM
You should be fine, most people don't start having issues until they go beyond 235/60/15, but then again, I just reread your question and noticed you had a 2" drop, maybe someone else will chime in.............KZ
kz1000ltd is offline
post #4 of 17 (permalink) Old Jan 20th, 06, 10:49 AM
Robert
I was running 215/65/15's on the front of the '69 with a 2" drop on a 15x7 rally. The tire you're considering in a little shorter and only about 3/8" wider. I don't see where there should be any problems but....
If your dealing with a local tire shop I bet they'ed mount one and check it out for you.
Robert
TC member #18
rojo is offline
post #5 of 17 (permalink) Old Jan 20th, 06, 11:31 AM
What kind of brakes? Based on your specs;
Drums..... maybe
Discs.......definitely
JD
'67 RS/SS 350
John Doyle is offline
post #6 of 17 (permalink) Old Jan 20th, 06, 12:49 PM
BonzoHansen's Avatar
Bingo. Those are tires sizes I would expect to see on the shelf (215/65, 225/60, maybe not 235/60). Iím sure your local tire guy would mount some up for you to check before you order the ones you want. He might charge you some fee. I would have, but I would have also let you apply that $$ towards the new tires when you come in for them. So free unless you buy elsewhere. Try that.
TC Member #13
BonzoHansen is offline
post #7 of 17 (permalink) Old Jan 20th, 06, 01:08 PM Thread Starter
John, I currently have four wheel drums on 14x6 rallys. I'm upgrading to 15x7 rallys so that I can convert the front brakes to disks. Do you think either configuration will cause rubbing?
post #8 of 17 (permalink) Old Jan 20th, 06, 01:44 PM
I have Hotchkis Springs on front of my 68 with 2" drop 235/60/15" cleared but now have new 215/65/15" cause I wanted a little taller tire but 225 should clear with no problem
edd Gordon is offline
post #9 of 17 (permalink) Old Jan 20th, 06, 01:48 PM
Call me Funk
Send a message via AIM to CFunK
I am going to say "no issue" with rubbing but can you post the dimension from the center of the hub to the fender lip, please.
-Funk
CFunK is offline
post #10 of 17 (permalink) Old Jan 20th, 06, 05:30 PM
If you haven't bought the 15's yet, go with the 4.25" bs. At least for the fronts. You might also want to go with a beefier rear tire than the 225.
My '67 rally set up is 15 x 7's w/ 4" bs with '69 front discs and 2" lowered PST springs. Tires are 215/65 15's and I do get the occasional rub. I removed my top two inner fender well bolts and trimmed back my well molding which did help somewhat, but I'll still get it, and when it happens I HATE it!!! Beleive me, you don't want it. Out back I have 255/60's on a 15 x 7 w/4" bs and fitment is perfect (stock '67 w/ drums & mono leaf).
You can see my set up on the sticky in the Paint & body work section "How I painted my Camaro"
JD
'67 RS/SS 350
post #11 of 17 (permalink) Old Jan 21st, 06, 07:17 AM Thread Starter
Thanks for your help. John, I really like the stance on your car. I think I'm gonna go with your set up.
post #12 of 17 (permalink) Old Jan 21st, 06, 08:14 AM
Call me Funk
Can you post the measurement from the center of the rim to the fender lip, please.
-Funk
CFunK is offline
post #13 of 17 (permalink) Old Jan 21st, 06, 01:35 PM Thread Starter
Hi Funk,
I have about 15.5 inches between center of hub and wheel well.
post #14 of 17 (permalink) Old Jan 21st, 06, 01:46 PM Thread Starter
Here's another fun tidbit of information I just realized. My tires in the front seem to be rubbing on the outer tie rods at full turn. I thought that they were 14x6, but now I think they may be 14x7. The codes are K19 and XN.
post #15 of 17 (permalink) Old Jan 22nd, 06, 05:50 PM
Call me Funk
Hi Funk,
You have 2" drop springs with that measurement??? What springs did you install?
Even with my "stock height" Moog 6308's I am at 15".
-Funk
CFunK is offline
