67 SS rallys - Team Camaro Tech
post #1 of 14 (permalink) Old Jan 20th, 06, 04:23 PM Thread Starter
phil
67 SS rallys
i have a 67 SS car that came factory with drum brakes on the front. would the DG code rims be the correct one for it, or would it be the XN code need a little help thanks all
rare4k is offline
post #2 of 14 (permalink) Old Jan 20th, 06, 04:41 PM
Vintage 68's Avatar
Re: 67 SS rallys
Those are 15" wheel codes.
Camaro non-Disc. rallys were 14"
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 14 (permalink) Old Jan 20th, 06, 05:39 PM Thread Starter
phil
Re: 67 SS rallys
no A DG and a XN rally are 14
rare4k is offline
post #4 of 14 (permalink) Old Jan 20th, 06, 06:34 PM
Tony
Re: 67 SS rallys
According to Chevrolet by the #'s book, DG was for the SS with disc brakes 14 x 6. FC is for an SS w?wide tires 14 x 6 doesn't say disc brakes. XN shows up as a 68 code. Hope that helps you out.
tonycamaro is offline
post #5 of 14 (permalink) Old Jan 20th, 06, 06:39 PM Thread Starter
phil
Re: 67 SS rallys
tony is the FC a rally or a steel rim
rare4k is offline
post #6 of 14 (permalink) Old Jan 20th, 06, 06:41 PM
Brad
RS3SDL2MG's Avatar
Question Re: 67 SS rallys
I did not think 67's camae with rallies without disk brakes ?? if it had drums it would have had either dog dish or po1 full hubcaps ?
1967 RS 327
RS3SDL2MG is offline
post #7 of 14 (permalink) Old Jan 20th, 06, 06:45 PM Thread Starter
phil
Re: 67 SS rallys
so a dog dish hub cap would be right for a SS car without disc brakes
rare4k is offline
post #8 of 14 (permalink) Old Jan 21st, 06, 09:23 AM
Vintage 68's Avatar
Red face Re: 67 SS rallys
Oops - that will teach me to go look at a list...
Sorry - I read 'DC' in your post not "DG" as you stated.
XN is not a '67 wheel code - so I didn't even get that far. (don't know what you edited?)
Rally wheels were available for non-disc applications in 14X5 so there use with anything other than stcok type skinnyer tires is limited. Hub cap says 'Chevrolet Motor Div. v.s 'Disc. equiped' on the SS's and 15" Z's.
Don't have the code book in front of me - but, I think code is 'DA' - I'll look it up later - I'm probably wrong the way my luck is going...
1968 Convertible
Some trucks
post #9 of 14 (permalink) Old Jan 21st, 06, 11:42 AM
Russ
rafbody's Avatar
Re: 67 SS rallys
"DA" is the code on rally wheels (14"x 5") for 67 camaro non ss disc brake. The 67 camaro's didn't have rally wheels on drum brake cars.
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
post #10 of 14 (permalink) Old Jan 21st, 06, 02:23 PM Thread Starter
phil
Re: 67 SS rallys
i just email the ORIGINAL owner of my SS with DRUM brakes and HE said in FACT it came with rally wheel flat cap and thanks for the code Rafbody!
rare4k is offline
post #11 of 14 (permalink) Old Jan 21st, 06, 07:36 PM
Tony
Re: 67 SS rallys
How about steel wheels with the rare mag hub caps??
post #12 of 14 (permalink) Old Nov 22nd, 06, 01:31 PM
Re: 67 SS rallys
Sorry to beat a dead horse here, but did we get an answer for the correct code? My 67 RS/SS with drum brakes DID come with rally's but I'm not sure on the correct wheel code.
Rockin' 4-wheel drums since 1969.
Toad is offline
post #13 of 14 (permalink) Old Nov 22nd, 06, 02:19 PM
madmax87's Avatar
Re: 67 SS rallys
This is from CRG if it helps at all.
1967-69 Camaro Wheels Year Type Brakes Code/Size Application(s)
1967 Steel Drum B 14x5 inch Base
FC 14x6 inch SS
Rally Front Disc DA 14x5 inch Base
DG 14x6 inch SS
DF 15x6 inch Z28
1968 Steel Drum FC 14x6 inch Base, SS
Steel Front Disc XF 14x6 inch Base, SS
Rally Drum XN 14x6 inch Base, SS
Rally Front Disc XG 14x6 inch Base, SS
DF 15x6 inch Z28
1969 Steel Drum FC 14x6 inch Base
XT 14x7 inch SS
IF 14x7 inch SS (observed on early LOS units)
YJ 14x7 inch SS
DF 15x6 inch Z28 (early)
AD 15x7 inch Z28 (middle)
YH 15x7 inch Z28 (late)
RPO N66 Either YA 14x7 inch SS style*
*removed from Dec 68 order sheet
madmax87 is offline
post #14 of 14 (permalink) Old Nov 22nd, 06, 02:20 PM
Lane
Re: 67 SS rallys
Heres what I have from Jason Scott restoration guide
B 14x5 standard all, exc SS
DA 14x5 Rally w/ fr disc exc SS
DF 15x6 Rally Z28
DG 14x6 SS w fr disc
FC 14x6 SS w/ opt tires (maybe John knows what these optional tires were)
I had same dilemna- installed factory disc brake and used the DG Rally
So DA would be best choice but as others have posted the drum brake 67 car didnt get rally. Perhaps others can suggest how you got them...
Oops see you have the SS car...I would think the DG 6" wheel the best rally choice...
Lane
67 RSS is offline
