I need tire selection help ASAP! - Team Camaro Tech
post #1 of 8 (permalink) Old Jan 27th, 06, 02:39 PM Thread Starter
Cool I need tire selection help ASAP!
I have a 69 that i want to buy rear M/T ET Street radials for.I would love to get 275/60R15 for the height but i am scared that i will not be satisfied if they rub.Does anyone here run that size?They will go on 8" Weld Draglite rims. so i am not sure of the backspace.If you think i will be sorry of the 275/60R15 would you get the shorter 275/50R15? I have Cal-Trac's with stock gas shocks.Please advise!!!!
shockers69 is offline
post #2 of 8 (permalink) Old Jan 27th, 06, 11:47 PM
Harley D
HarleyD67's Avatar
Re: I need tire selection help ASAP!
The 275/40's are definitely a safer bet, especially if you don't know BS of your wheels. If I where you I would measure BS first then look into fitment. Is the car at stock ride height? If your wheels have less than 4.5" BS you will more than likely have issues with the inner fender lip.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #3 of 8 (permalink) Old Jan 29th, 06, 10:21 AM
Patrick
when I first got my car it had 236/60's on it then I put 275/60's on, they fit but when I hit a bump they scrubbed. I had to raise the rear about 1.5-2''. All is good now....Here is how it sits......
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
post #4 of 8 (permalink) Old Jan 29th, 06, 10:22 AM
Patrick
when I first got my car it had 235/60's on it then I put 275/60's on, they fit but when I hit a bump they scrubbed. I had to raise the rear about 1.5-2''. All is good now....Here is how it sits..Fronts are 235/60
383 IS SOLD!
Building a 489BBC
post #5 of 8 (permalink) Old Jan 29th, 06, 11:05 AM Thread Starter
What a beautiful car speedfreak!I am going to order 275/60R15 they look awsome i have a 4:10 ratio and this taller tire will help lower my RPM's on the road.How did you raise your ride height?
post #6 of 8 (permalink) Old Jan 29th, 06, 01:10 PM
Jack
shockers69,
Here's my 69 with 275/60/15s MT's. Haven't cleaned it up since the drags. They are on 15x8, 4.5BS wheel vintique wheels but I run a 1" shorter (1/2" each side) rear end. Springs are Calvert split-monoleaf and shocks are QA-1s. They do rub on corners or bumps with turns with only me in the car. I only run them on the drag strip. I use 255/60/15 on the same wheels now and before I shortened the rear and had no rubbing problems. Hope this helps. PM me if you need more photos.
Jack Eggers
67 Camaro, Blue, 327, 4L60E, Dana 60
10 Camaro 2LT RS, IBM, V6, Auto
10 Tundra Crew Cab, Silver, V8, Auto
16 Camaro 2SS, Hyper Blue, A8
17 ZL1, Hyper Blue, M6
Jack Eggers is offline
post #7 of 8 (permalink) Old Jan 29th, 06, 01:21 PM
Check out this old thread I commented on
https://www.camaros.net/forums/showthread.php?t=33099
I had the 26 x 10.5 x 15 MT ET Streets on the rear of my 69 using a 7" Weld rim (its spec'd to do it, previous owner was into dragracing).
and
Brian Lewis is offline
post #8 of 8 (permalink) Old Feb 3rd, 06, 06:39 PM
Patrick
I lengthened the rear shackles about 1.5''. I hope you dont have a th350 because if so those 4.10's are gonna be terrible on the street.
383 IS SOLD!
Building a 489BBC
